Author Topic: 5th gear jumping  (Read 1966 times)
Offline Steris
Re: 5th gear jumping
« Reply #15 on: July 18, 2022, 03:48:30 PM »
Ive had the engine out and stripped, selector forks aren't worn at all but the 3 dogs on the 4th/5th gear are, i have now fitted the gear train out of the CB350 twin. This has 5 dogs and looks much more robust and the dogs engage fully. Its all back up and running now and I've done a few hundred miles without any issues, so fingers crossed this has fixed the problem.  :D
« Reply #16 on: July 19, 2022, 01:09:19 PM »
Wow pleased you sorted it interesting that you could fit CB350 twin parts.
Offline florence
« Reply #17 on: July 19, 2022, 01:46:39 PM »
yes, the gearboxes are almost identical and much easier to find.
Online Bryanj
« Reply #18 on: July 19, 2022, 01:49:22 PM »
The centre selector is the same part number,
Did you use 350 outer selectors or 500 and is it just ratios yhat are different?
Offline Steris
« Reply #19 on: July 20, 2022, 02:55:12 PM »
Hi Bryanj
The outer selectors are as good as new so they are the original 500 ones. The centre fork is 350 as is the 4th/5th gear. The ratios are the same just the needle bearings on the ends are different.
Online Bryanj
« Reply #20 on: July 20, 2022, 07:35:58 PM »
I knew there was crossover between the 250/350/450 twins and the 500 four but never had them in bits side by side to compare
