Author Topic: 72 rear rim  (Read 1291 times)
Offline 1234pot
Re: 72 rear rim
« Reply #15 on: May 11, 2021, 06:23:59 PM »
Many thanks Phil. Will do.
Re: 72 rear rim
« Reply #16 on: May 12, 2021, 08:41:48 AM »
We used to crack test wheel sets on underground trains using a magnetic flux. An electric current was then applied providing a magnetic field around the wheel. The metal particles were then drawn into the cracks if any existed, indicating the wheel was cracked and only fit for scrap. I'm not sure if you can apply this method to your wheels and if the chrome layer will affect the result in any way but I have seen DIY type kits available.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline 1234pot
Re: 72 rear rim
« Reply #17 on: May 12, 2021, 08:54:24 AM »
The science is sound Dave so I don’t see why it wouldn’t work. In this instance I’m in the hands of a pretty experienced wheel builder.  I’m looking forward to seeing it for myself and will definitely post a pic.
Offline allankelly1
72 rear rim
« Reply #18 on: May 12, 2021, 08:48:33 PM »
Another crack test used is Magnaflux
It’s a liquid I believe that you apply that penetrates microscopic cracks then once the excess fluid is “washed off” you  then inspect under a UV lamp as the fluid  in the crack remains and glows under a uv inspection lamp?
« Last Edit: May 12, 2021, 08:53:44 PM by allankelly1 »
