Author Topic: Nearly there  (Read 5231 times)
Offline mhirst121
Nearly there
« on: January 24, 2010, 05:04:56 PM »
Well I thought you all might like to see some pics of my progress so far. The bike was an ebay buy and alot rougher than I first thought once stripped down. The bike has been completely rebuilt and painted, apart from the motor which was ok. The first pics are as I bought it in its horrible burgundy guise. The tank and panels have been done in basecoat and orange metal flake(blast from the past !!!). I don`t like the stripes I have put on the tank so have some originals coming and will redo the entire tank again when the weather picks up a bit. Hope you enjoy and will post some better ones in the daylight. Up till now I have spent about 2 1/2 months on the resto.
Cheers,
MartinH
« Last Edit: January 25, 2010, 04:53:52 PM by mhirst121 »
Offline dave400
Re: Nearly there
« Reply #1 on: January 24, 2010, 06:09:47 PM »
Looks great!  8) 8)
Offline mhirst121
Re: Nearly there
« Reply #2 on: January 24, 2010, 07:09:50 PM »
Anyone know an easy way to get the main stand spring on!!! >:( >:(
Offline mick
Re: Nearly there
« Reply #3 on: January 24, 2010, 07:41:17 PM »
This is how i have done it before on my 750, start with stand, spring etc off the bike, attach the c shaped plate to the lug on the frame & attach the spring to it, then attach the the other end of the spring to the centre stand, now you should be able to hold on to the stand and pull on it to line the holes up with the frame for the stand spindle and push it into place  ;) job done just tighten everything up  :) cheers Mick
Offline mhirst121
Re: Nearly there
« Reply #4 on: January 24, 2010, 07:55:24 PM »
Thanks Mick will give that a go.
Re: Nearly there
« Reply #5 on: January 24, 2010, 08:44:55 PM »
This may be an urban myth but...
Open up each "link" of the spring with a flat bladed screwdriver and insert a penny. slip the "extended" spring over both retainers and then remove pennies with a pair of pliers.  ;D
I think this came from .net but I don't remember who...
2022 Tiger Sport 660
Offline mhirst121
Re: Nearly there
« Reply #6 on: January 25, 2010, 04:44:57 PM »
Well Steve I am impressed. The spring thing worked a treat, only I used washers not rich enough to use pennies(spent all of them on my bike ;))
Cheers,
MartinH
Re: Nearly there
« Reply #7 on: January 25, 2010, 04:51:19 PM »
Amother one with new life breathed into it, sure looks good.
Den
Offline UK Pete
Re: Nearly there
« Reply #8 on: January 25, 2010, 06:20:06 PM »
Yes that does look real good well done you must be well proud
Pete
Offline Seamus
Re: Nearly there
« Reply #9 on: January 26, 2010, 11:36:22 PM »
Really nice job that. I always liked the 500. Are the exhausts available now?
Re: Nearly there
« Reply #10 on: January 27, 2010, 08:44:45 AM »
Yes, you can buy individual or full sets from David Silver.
Offline mhirst121
Re: Nearly there
« Reply #11 on: January 27, 2010, 07:41:48 PM »
As Steve said, yes the exhausts and brackets are available from Silvers. They were an absolute pig to fit, the two small link pipes are too short in my oppinion and they are out of alignment. Just had to make the best of a bad job by modding the brackets and fiddling around.
Has anyone else had this problem????
MartinH
Re: Nearly there
« Reply #12 on: January 28, 2010, 05:31:37 AM »
Yup, the brackets are pattern so probably not quite right, allong with 40 year old exhaust assembly jigs
Offline toucheturtle
Re: Nearly there
« Reply #13 on: February 02, 2010, 10:57:19 AM »
Where are you getting the tank stripes from. I've bought a set from Dave Silver but am not impressed and could do with a better set.
Offline mhirst121
Re: Nearly there
« Reply #14 on: February 02, 2010, 08:07:31 PM »
Those are the ones I have. I was as unimpressed as you, but it seems thats the best available, without getting them specially cut. Are the lines on yours all shapes, as if they were done freehand??
KnK in the states do some but they look like they are the same thing.
http://www.knkcycles.com/hondaCB500.html
MartinH
