Author Topic: Black Bomber not charging  (Read 3455 times)
Re: Black Bomber not charging
« Reply #30 on: May 22, 2021, 08:15:08 AM »
Looking at your figures again and  comparing them to the 5-speed Honda graphs Roy,  I think you now have a really nice charging system with the added bonus of the solid state regulator to stop you 'boiling the battery' or blowing bubs if the battery isn't perfect.
« Reply #31 on: May 22, 2021, 09:29:06 AM »
That's good to hear, I was thinking it looked a bit low compared to the graph. I'm not sure the output is so great to ever activate the regulator but knowing it's there gives peace of mind.
I shall now get it run in and see how the charging goes. The good thing is I have learned a whole lot about electrics whilst doing this. Thanks guys for all the advice along the way.
« Reply #32 on: May 22, 2021, 10:55:57 AM »
One feature of that regulator is that if you have a poor battery connection or a failing battery, it prevents the high voltage from the alternator popping every bulb on the bike. It's a very neat little circuit for 1968 when it 1st appeared, in terms of solid-state electronics (it uses a power thyristor to clamp the excess voltage).
« Last Edit: May 22, 2021, 10:57:52 AM by AshimotoK0 »
« Reply #33 on: May 22, 2021, 07:46:52 PM »
I found this from a CB77/450 Service Bulletin attached Roy .. From 1968
« Reply #34 on: May 22, 2021, 07:49:26 PM »
I found this from a CB350/CB450 Service Bulletin attached Roy .. From 1968
(Attachment Link)
« Reply #35 on: May 22, 2021, 08:07:15 PM »
Thanks Ash. I would appear to be back to front, ie much higher amperage with the lights on. I would have thought it would be the other way around.
I think I may just ride it with the lights on all the time, I get at least a 4 amp charge that way.
« Last Edit: May 22, 2021, 08:19:38 PM by royhall »
« Reply #36 on: May 23, 2021, 08:52:27 AM »
Yes it is confusing ... but as long as you have a decent positive charge once the engine is  running at all engine speeds you should be OK. It's really the ability of the charging system to replenish the battery charge lost, after cranking the engine with the electric start /ignition coil current,  which is critical (provided that the running charge is positive).
« Reply #37 on: May 24, 2021, 06:02:49 PM »
It's a bit rough and ready (I will try and improve it when I have time) but this is now the wiring diagram that reflects what is actually on my 1967 Black Bomber. Fitted is a new harness with original Bomber wire colours, an alternator and rotor from a later K4 model, a voltage regulator from a later model and an AGM battery. It is all fitted and working correctly. Hope this is a help to anyone that has been watching this thread.
