Author Topic: gap  (Read 1652 times)
Offline murdock
gap
« on: May 25, 2021, 08:02:06 PM »
Hello, after 40 days the cruzzing pistons have arrived in Spain, if I had bought them elsewhere I would already be enjoying the motorcycle, just today I started a dispute with PayPal to get the money back and the shipping information was updated. 14 days in Tokyo and 25 days nobody knows where, they are still in customs, but when they arrive I must go to the rectifier (as they are called here) to enlarge the cylinders,
what is the gap I need? I have read that Honda works with very little tolerance, but I do not know what exactly, if someone could help me with this I would appreciate it
I have bought pistons of + 0.50
59 mm.
I don't understand the manual very well
Re: gap
« Reply #1 on: May 25, 2021, 11:19:43 PM »
Not sure if this is what you are looking for murdock - this applies to 400Four and not sure if same for 550
http://www.sohc.co.uk/index.php/topic,24199.msg233777.html#msg233777
'1 thou' equals 0.0254mm
Online Bryanj
Re: gap
« Reply #2 on: May 26, 2021, 12:15:15 AM »
Pisto to bore clearance is 1 thousandth of an inch or 0.025mm and yes it is that small no matter what the people machining the bores say
Offline fogrider
Re: gap
« Reply #3 on: May 26, 2021, 09:50:32 AM »
There are 2 errors on that chart which will create some confusion !
Re: gap
« Reply #4 on: May 26, 2021, 10:08:17 AM »
Which errors 🤔
Re: gap
« Reply #5 on: May 26, 2021, 10:19:18 AM »
Which errors 🤔
Piston diameter of 54.47 to 58.49 with a range of 4.02mm  ;D that would let some oil past  :o
Re: gap
« Reply #6 on: May 26, 2021, 10:30:44 AM »
Which errors 🤔
Oh yes, I see now Nigel ☺️☺️☺️
Offline Moorey
Re: gap
« Reply #7 on: May 26, 2021, 12:23:01 PM »
  It makes getting the rings in easy though.  ;)
Re: gap
« Reply #8 on: May 26, 2021, 12:41:03 PM »
Yep, you could throw them in like quoits from the other side of the workshop. ;D
Offline fogrider
Re: gap
« Reply #9 on: May 26, 2021, 01:01:54 PM »
The other one is in piston diameter - 58.35  is 2.297, their figure shows a piston bigger than the original.
I find it better to substitute MAXIMUM for their word serviceable, it makes more sense to me that way.
Offline murdock
Re: gap
« Reply #10 on: May 26, 2021, 01:58:35 PM »
Obviously the author of the manual was not a sociable person or somebody disturbed, I don't know ..jua jua
but I still do not know what the gap would be that I should request from the machinist between cylinder and piston
Offline murdock
Re: gap
« Reply #11 on: May 26, 2021, 02:43:13 PM »
if someone fills this photo correctly it would do humanity good
Re: gap
« Reply #12 on: May 26, 2021, 02:49:37 PM »
Your picture is incorrect. The piston will be in the centre of the bore and as you are using Cruzinimage pistons you need a piston to bore clearance all round  at the piston skirt of 1 thou inch which equates to 0.0254mm
Offline murdock
Re: gap
« Reply #13 on: May 26, 2021, 04:05:18 PM »
Ok, perfect, thank you very much
Offline fogrider
Re: gap
« Reply #14 on: May 26, 2021, 04:45:40 PM »
So to fill the figure in on Murdocks' drawing would be two thou , one each side ?
