Author Topic: What are the symptoms of a faulty oil pressure relief valve?  (Read 517 times)
Offline SteveW
Found out the other day that my oil pressure switch is leaking at the screw thread where the wire to the light goes.
The switch is just over 3 years old so I’m wondering if it’s just switch failure or there is something more sinister going on?
Did over a hundred miles last Sunday, bike behaved perfectly, except the sprocket cover had about half a cup of oil in it which is now over the front lawn.  :(
Big thanks to Nurse Julie who sorted me out a replacement switch in mega quick time  :)
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: What are the symptoms of a faulty oil pressure relief valve?
« Reply #1 on: May 29, 2021, 09:27:30 AM »
Just a bad switch probably unless the oilpressure is incredibly high and that would give bigger leaks
« Reply #2 on: May 31, 2021, 08:49:28 AM »
Oil switch leaks / failures seem quite common again I guess its connected with thin oils & additatives they use.
My neighbours 3 year old Kia 4x4 oil pressure switch failed with the light staying on most of the time!
Kia wanted him to pay for the diagnosic oil pressure check - so much for 7 year warranty - it turned out cheaper to get his local garage to fit a new switch.
« Reply #3 on: May 31, 2021, 10:13:27 AM »
I suspect that cheap Chinese switches are not made to the same quality standards of original Honda switches.
Offline SteveW
« Reply #4 on: May 31, 2021, 11:15:34 AM »
Put the new switch in yesterday and did about 5 miles, no leaks at all.
The old switch still worked normally, it was leaking around the brass insert that the wire to the bulb is screwed to.
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline ST1100
« Reply #5 on: May 31, 2021, 12:16:52 PM »
Resin does age, suffering due heat cycles and also might be sensitive to (modern) oil additives (ether comes to mind)...
Observing similar issues on resin sealed wiring exits of oil cooled alternators...
STOC #637
