Author Topic: Odd Bearing Retainer (Front Wheel)  (Read 740 times)
Offline Raygun
« on: June 03, 2021, 01:35:23 PM »
1977 CB550 F
I was under the impression the front wheel bearing retainer had only 4 notches, though this one seems to have a few more?!
Does anyone know what tool is required to remove this as the standard CB500 Front Wheel Bearing Retainer tool doesn't look like it's the right one
Re: Odd Bearing Retainer (Front Wheel)
« Reply #1 on: June 03, 2021, 02:17:07 PM »
The slots appear to still be opposite each other though - I used a piece of 25mm wide x the slot thickness bar (x the bearing retainer diameter for the length) with a slot filed in it to clear the spindle end. I then put an adjustable spanner/wrench on it as the lever to turn the retainer. May need to use a punch to get it started
« Last Edit: June 03, 2021, 02:19:36 PM by philward »
« Reply #2 on: June 03, 2021, 04:19:35 PM »
Looks home made and i think i can see half a hole on the hub where an original staking has been drilled out, try some heat to loosen the crud
