Author Topic: Fitting Throttle cables CB 750 K7  (Read 717 times)
Offline Alexandlinda
« on: July 12, 2021, 06:21:34 PM »
Greetings all. I have installed new throttle cables on my 750 K7 but I find that when the securing nuts on the guide pipes at the handlebar end are fully tightened, the rearmost one (has a little flange on the inner part) still has some slack in it meaning that the guide pipe can wiggle around. I have been reluctant to apply much force as the alloy of the swithc housing is notoriously weak. Am I missing something? If anyone can enlighten me that would be great.
Alex
Honda CB750 K7 - 1977 (almost done)
Yamaha XJR 1300
Offline Skoti
Re: Fitting Throttle cables CB 750 K7
« Reply #1 on: July 13, 2021, 07:10:30 AM »
Cheap and nasty aftermarket cables.
You could cut a slot in an aluminium washer and place it on the end of the flange then tighten up the nut.
That worked for me.
Good luck
Skoti
« Last Edit: July 13, 2021, 10:14:29 AM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #2 on: July 14, 2021, 05:10:14 PM »
Thanks for the tip which sound like a solution. The cables came from David Silver!
All best
Alex
Yamaha XJR 1300
« Reply #3 on: July 14, 2021, 05:14:15 PM »
Hi again.  What was the thickness of the washer you used?
Alex
Yamaha XJR 1300
Offline Skoti
« Reply #4 on: July 14, 2021, 07:42:15 PM »
I used a 1.5mm thick washer, but back then my cable came from Hi-level.
It's since been replaced by a Dave Silvers cable which actually fits fine without needing the washer!
Good luck
Skoti
Skoti
1976 Honda CB750F1
