Author Topic: Split Crankcase Oil Seal Fitting - Clamp or Press In - Which is Hondas' way ?  (Read 439 times)
Offline 400 Cafe Racer
Hope to get on further with the engine rebuild shortly, but on stripping I noticed some seals seem to have been "clamped in when fitting" evident by the significant oozing of the plastic profile of the seal protruding inside the case. This would make it almost impossible to extract a seal  without splitting the casings.
OR
Should they all be pressed in externally after mating the casings.
Interested on your thoughts. :-\
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest    - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
No, you fit them as you are building the bottom end up. Also advisable to put a very light smear of Hondabond on the housings where they fit.
Thanks Nurse Julie,
Thanks for  confirming what I thought. I have not come accross it specifically mentioned by Honda manual but felt that it should be the case in normal engineering practise.
I did see some "pinching" of the circumference on one seal where the 2 halves of the casing join, which led me to think that it had been fitted "clamped".
I am in the process of doing the internal measurement and inspection of components at the moment and will be in touch with you later. Thanks.
Regards
