Author Topic: tank de-rust  (Read 1257 times)
Offline mickwinf
tank de-rust
« on: August 02, 2021, 03:26:53 PM »
Ok i know it has been covered before but it is doing my head in! I have de- rusted the interior of my spare tank using phosphoric acid as recommended by Ashimoto. It works very well leaves it completely clean metal. The issue i have is it rusts again overnight, and had the same problem with my old tank. So these are the methods i have used with no success. If i flush with clean water then with petrol, it rusts. If i let dry without flushing the phosphoric acid it leaves a black tar like substance which only cleans off using more acid. I also tried swilling some diesel around and still it rusts! I don't want to line it as most people on here are dubious about them so what do i do? when the tanks are new they dont flash rust so why does it happen?
Re: tank de-rust
« Reply #1 on: August 02, 2021, 04:03:52 PM »
Mick, I seem to remember (I think) Nurse Julie recommending a bit of diesel oil sloshed around the tank as it contains oil and therefore keeps it rust free. Normal petrol contains ethanol that will rust your tank as it attracts water and holds in suspension.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Re: tank de-rust
« Reply #2 on: August 02, 2021, 04:05:02 PM »
Rince out with de ionised water and then swish diesel around inside the tank to create an oily layer.
Re: tank de-rust
« Reply #3 on: August 02, 2021, 06:58:26 PM »
I have used stuff like Trustran (a rust convertor) that is like a gun blueing liquid on small items. I used Evaporust on my tank then swilled it with 2T oil. Quite a few rust convertors chemically react with the rust to form a none rusting oxide protective layer rather than removing the iron oxide from the metal thus enabling it to go rusty again.
Re: tank de-rust
« Reply #4 on: August 02, 2021, 09:05:46 PM »
"when the tanks are new they dont flash rust so why does it happen?"
When steel is run through the roller mill to progressively bring it to it's sheet thickness it effectively ends "forged" with very high compression and, to a certain degree, refined inpenetrability as the final surface. This is generally pretty resilient to surface corrosion as it's just so compacted,  with any subsequent disturbance causing reduction of that finish whether starting with corrosion which once removed have partly destroyed that finish.  All subsequent treatments by removing rust can't reinstate that first finish status, at which point it will need some element of protection.  What that is I'm not sure in terms of effectiveness, but it can't be just left alone.
Re: tank de-rust
« Reply #5 on: August 02, 2021, 09:38:58 PM »
I assumed they had a coating of some sort like yellow zinc!
Re: tank de-rust
« Reply #6 on: August 02, 2021, 11:37:54 PM »
I'm not aware that they were coated in any way. By comparison some of the inside of fuel caps are zinc plate with a clear and obvious difference to the tank internal.
Offline Athame57
    • SeaWitch Artist
Re: tank de-rust
« Reply #7 on: August 03, 2021, 01:27:05 AM »
I'd better hurry up and de-rust my spare tank then.....at this rate diesel will be nearly extinct!
1978 CB400F2 called Elen.
Offline Oz350Four
Re: tank de-rust
« Reply #8 on: August 03, 2021, 01:33:01 AM »
I've used 2 stroke fuel mix as I didn't have diesel at the time and it worked a treat...
Offline kevski
Re: tank de-rust
« Reply #9 on: August 03, 2021, 08:00:04 AM »
As Julie says, rinse with D,I water then rinse with diesel, as a former metal chemist i could go deeper but won't.
Offline mickwinf
Re: tank de-rust
« Reply #10 on: August 03, 2021, 08:44:42 AM »
Thanks for replies, i have tried these methods, the only difference to Julies was i used tap water to flush not distilled. Has diesel in at the moment and has rusted again.
Re: tank de-rust
« Reply #11 on: August 03, 2021, 09:05:23 AM »
You could try a rinse with a bi carbonate of soda straight after a water wash as it should neutralise any remaining acid to help prevent flash rusting and see what you get.
Don't put the bi carbonate in straight after acid, rinse first then go in with bi carbonate wash.
Re: tank de-rust
« Reply #12 on: August 03, 2021, 09:59:51 AM »
Washing Soda crystals or household bleach are heading up the ph scale if you want to asses the affects of bringing it more alkaline with easily available chemicals.
Sodium hydroxide "drain cleaner" is further out on the scale too.
Offline Kelly E
  • Geriatric Hooligan
Re: tank de-rust
« Reply #13 on: August 03, 2021, 06:45:59 PM »
I use EvapoRust and rinse with diesel. The last thing I am going to put in a freshly derusted tank is water. When you dump out the diesel into a jug let the sludge settle and pour the diesel back into the tank for another round of rinsing. I rinse at least 4 or 5 times. Never have had any flash rust with this method. The diesel can be used over and over again. Just keep pouring off the clean diesel and dump the sludge.
The Rust Brothers Garage Collection
1974 Honda CB550 K0
1975 Honda CB400F Super Sport
1979 Honda CB750F Super Sport
1980 Suzuki GS1100E
1982 Honda CB900F Super Sport
1983 Honda CB1100F
1984 Honda VF700S Sabre
1984 Honda VF1000F Interceptor
1990 Moto Guzzi 1000 Le Mans
1994 Kawasaki Concours ZG1000
2006 Harley Davidson Fat Boy
Re: tank de-rust
« Reply #14 on: August 03, 2021, 07:25:49 PM »
De Ionised water is just fine, it's very cheap, readily available and prevents flash rusting. Then swill round with diesel.
