Author Topic: Starter motor cable  (Read 604 times)
Starter motor cable
« on: August 21, 2021, 12:53:28 AM »
Quick question; I went to connect the power cable to the starter motor terminal and I can't remember the sequence for the washers.
I've got an insulating washer on the base, next to the casing. Then the cable fixing, then a flat metal washer, a small lock washer, then the fixing nut on top.
Is that right? Should have noted the order when I took them off, but didn't for some reason. 🙃
Online McCabe-Thiele (Ted)
Re: Starter motor cable
« Reply #1 on: August 21, 2021, 02:14:39 AM »
That's what mine is but it has been removed previously by the PO so can't be 100% but sounds logical.
I'm finding I did not take enough photos before I took stuff apart!
I've just found a tub with some odd looking rubber fitments - at present I have no idea what I took them off - eventually I might have to take a photo & ask but am conscious I ask too many questions as it is.
Online Bryanj
« Reply #2 on: August 21, 2021, 09:16:28 AM »
Never too many Ted, ive been doing Hondas since 73 and still learning
Offline 4wDaz
« Reply #3 on: August 21, 2021, 10:10:54 AM »
Mine has insulating washer, thin washer, spring washer, half nut, cable, spring washer then half nut
« Last Edit: August 21, 2021, 10:13:09 AM by 4wDaz »
Genuine And Aftermarket Motorcycle Parts Supplier
« Reply #4 on: August 21, 2021, 11:03:58 AM »
Thanks guys. I should be OK now. I'll fit the 2 half nuts as in the photo.
