Try our new info resource - "Aladdin's Cave" (Main menu)Just added a separate link to Ash's Dropbox thread (shortcut)
No rubber bit just bolts tight to bottom yoke
Yes that's correct.
No. The clip you are talking about mounts on the under side of the steering stem between the stem and the right fork leg. If you look on the underside of the steering stem you will see the mounting hole.
My 500-4 has the same clip, no idea why it has a 375 middle number though unless it got superceded, I’m going to be make no some cable clips when I get my Gateros plating kit, if they turn out ok and you still need one Ted I’ll make you one.
