Author Topic: Rear brake pedal alignment marks.  (Read 391 times)
Offline billdn
« on: August 25, 2021, 04:10:26 PM »
Should these 2 marks on pedal and shift align or is it just coincidence 🤔.  If so how because the spring doesn't want to go that far under tension.
Re: Rear brake pedal alignment marks.
« Reply #1 on: August 25, 2021, 04:36:40 PM »
Yes, that minute little black divot on the end of the shaft lines up with the divot on the lever. You may have to move a spline or two either way for comfort of your foot but the dots are the starting place.
« Last Edit: August 25, 2021, 04:40:55 PM by Nurse Julie »
« Reply #2 on: August 25, 2021, 04:37:23 PM »
I've just checked my rear brake pedal shaft  - there is no marking aside from the small scratch I enscribed before removal to realign when I refit the pedal.
Likewise there is no spot on the pedal itself either - both I'm pretty sure are original parts.
Confusing as you seem to have two spots one is a small dot the other a circle?
I've just had another look after rubbing the end of the shaft with some fine emery paper and can make out a letter T -it's nowhere near the top either!
My new brake pedal does have a spot like yours though - I havent as yet fitted mine so will be interested to read how you sort it.
« Last Edit: August 25, 2021, 05:10:41 PM by Macabethiele (Ted) »
Offline billdn
« Reply #3 on: August 25, 2021, 06:30:37 PM »
Cheers NJ - my pic looks almost identical to yours, so may be a spline or 2 adjustment needed for comfort.
