Author Topic: The rubber sump pick up pipe i/d size anyone?  (Read 431 times)
« on: September 02, 2021, 09:29:06 AM »
DS don't supply the rubber hose for the sump pick up pipe (gearbox oil supply?) mine is in poor shape does anyone know the correct inside diameter please or a supplier?
Would silicone pipe replacement be okay as I have in the past obtained car brake vacuum lines and used silicone tubing?
Most Nitile rubber listings show max heat range as 110 deg C I would think hot engine oil exceeds this?
.https://www.ebay.co.uk/str/performancepartsltd?_trksid=p2047675.l2563
I have measured the o/d of the metal pipe on the filter housing - it's 6mm on the pipe discounting the built in olive so would a 5 mm pipe be too tight ?
« Last Edit: September 02, 2021, 09:07:13 PM by Macabethiele (Ted) »
Re: The rubber sump pick up pipe i/d size anyone?
« Reply #1 on: September 06, 2021, 10:34:27 PM »
https://www.ebay.co.uk/itm/384349352378?ssPageName=STRK%3AMEBIDX%3AIT&var=652522935873&_trksid=p2060353.m2749.l2649
My pipe arrived today enought to make several pick up pipes not bad for £2.17 sample.
They confirmed it was resistant to hot oil etc.
P.S. It's 5 mm i/d
« Last Edit: September 07, 2021, 10:27:49 AM by Macabethiele (Ted) »
