Author Topic: Is this normal chain wear?  (Read 13897 times)
Offline Veedunk
« on: September 06, 2021, 10:05:36 AM »
Hi, I’ve taken my cylinder head off due to trying to find an oil leak…I’m about to replace the gaskets/seals and hope that fixes the problem but before it all goes back I wanted some advice about these chain marks? Is that normal wear to the inside of the head and the barrel casing?
Many thanks
Re: Is this normal chain wear?
« Reply #1 on: September 06, 2021, 11:09:23 AM »
No either the tensioner isnt workinh and/or the cam chain is worn out
« Reply #2 on: September 06, 2021, 11:25:08 AM »
Looks like a good candidate for a strip complete strip down.
1978 Honda CB550K3.
Offline florence
« Reply #3 on: September 06, 2021, 11:42:26 AM »
erm, good job you took it apart.
« Reply #4 on: September 06, 2021, 11:48:24 AM »
Yup its a full strip, there is no link on those hyvo chains, i know they must have been assembled in the first place but those pins always look twisted at the ends to me
« Reply #5 on: September 06, 2021, 01:03:02 PM »
The cam chain isn't a Hyvo Bryan but the primary chain is 😊😊😊
« Reply #6 on: September 06, 2021, 04:49:31 PM »
 Im sure the 650 has a small hyvo camchain lick the 250N
« Reply #7 on: September 06, 2021, 05:13:08 PM »
Indeed you are probably 100% correct and I apologise. I didn't see that it was a 650 and I've never seen a complete 650 in person ever, let alone the innards of the 650 engine 😊😊😊😊
« Reply #8 on: September 06, 2021, 07:37:00 PM »
No need for appologies Julie, the day we stop learning is the day we give up! Just for info the 650 is a stroked 550 not a bored one
Offline Veedunk
« Reply #9 on: September 07, 2021, 07:25:48 AM »
Thanks for all the replies, not the answer I was hoping for though!
Before I go ahead and strip it down, do you think these could be old wear marks? I’m only asking because I bought this bike a year ago after a full rebuild during lockdown by the previous owner, it’s probably done less than 1000 miles since then.
I will drain the oil today and see what sort of condition it is in.
Thanks again
Online Sesman
« Reply #10 on: September 07, 2021, 08:07:34 AM »
Drop the sump and also inspect the oil pump and filter.
« Reply #11 on: September 07, 2021, 08:41:48 AM »
Rebuilt? By who and how and what was replaced plus was it set up.correctly afterwards, especially the cam chain adjustment. Those marks look new and shiny so i would say were recent and done by this chain and to my mind that compromises the chain. Sorry
Online Sesman
« Reply #12 on: September 07, 2021, 09:19:24 AM »
As a minimum I’d drop the sump and inspect the primary chain, filter and oil pump.
Offline Veedunk
« Reply #13 on: September 07, 2021, 11:54:51 AM »
Ok I’ve dropped the sump, removed the oil filter and removed the oil pump…
There are very, very fine metal particles in the oil filter and the oil from it, same with the oil pump, if I didn’t know better I probably wouldn’t have noticed them. However when I drained the oil from the sump there were some bigger particles which I’ve tried to show an example with the photo, but certainly not much considering the amount of wear.
I don’t know what to look for on the primary chain if I’m honest, it looks normal to me.
As for what was rebuilt by the last owner, I don’t really know, but I will try and find out.
The bike has always run well but not been as quick as I would have expected but I don’t have anything to compare it with as I’ve always had modern bikes. Would this sort of wear prevent the bike from revving fully as its always sounded like it’s screaming at about 6000rpm?
« Reply #14 on: September 07, 2021, 12:26:39 PM »
There's something very and distinctly unusual about that chain and wear in first picture, maybe give us a clear picture of the chain stretched out and a picture of the cam sprocket to help opinion of what's really going on there.
A "Hyvo" type if ever fitted doesn't ordinarily have a centre set of link plates running along the chain (unless that first picture has two runs next to each other as it lays there) it certainly looks wrong from that picture.
Generally a Hyvo will have sprockets looking like small gear teeth rather than the curved bottom form of conventional link chain hardware.
Unusual to touch the sides of castings to to anything of that degree illustrated.
