Author Topic: Can anyone identify these items please?  (Read 746 times)
« on: September 08, 2021, 11:05:15 AM »
The big bracket came with my bike in a box of oddments it's not my rear exhuast bracket (I have that) could it have been part of the original system  any ideas please?
The two long bolts might have come from the front end somewhere as they were in a box with my Instrument bracket - obviously not original with the allen key head - they have a ferrule with some broken rubber bits ?
The two in the right of the photo have an odd hole in the ends?
I know I should have taken more photos as I stripped the bike down - at the time I told myself it's obvious - I clearly have not taken into account my Goldfish memory - yes the Castle in the bowl is a surprise every time!
..where do these fit by Macabe Thiele, on Flickr
« Last Edit: September 08, 2021, 12:35:38 PM by Macabethiele (Ted) »
Re: Can anyone identify these items please?
« Reply #1 on: September 08, 2021, 11:10:27 AM »
Exhaust silencer hanger bracket and the 2 bolts at the end are headlamp reflector fitting bolts, no idea about the middle ones.351 on the fiché for the reflector bolts.
« Last Edit: September 08, 2021, 11:14:04 AM by Nurse Julie »
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: September 08, 2021, 11:55:53 AM »
Interesting thing about the diagram Julie is that there are two cables going into the indicators yet I only have one....
1978 CB400F2 called Elen.
Offline TrickyMicky
« Reply #3 on: September 08, 2021, 12:08:32 PM »
Diagram is possibly of a USA model. I believe they had a 21/5W bulb in the indicator, the 5W part being used as daytime running lamps. It also shows a headlight plug connector which is used for a sealed beam unit.
« Reply #4 on: September 12, 2021, 09:24:37 PM »
Thanks for the two identified parts - my Motad System did not use that bracket - still haven't found where the centre two bolts came from - time will reveal!
« Reply #5 on: September 13, 2021, 02:03:57 PM »
I'm wondering if the bracket which bolts ( and holds the headlight?, No 306) to the top yoke has been damaged in the past and the 2 long bolts which are part of it were cut off and replaced by those bolts, they appear long enough.
The headlamp bracket bolts are all original - it's bugging me as where they came from as I remember they were quite tight. I'm currently viewing my recently retrieved strip down pictures. They are not long enough for the front upper engine mounting brackets but there is another bracket at the rear that is triangular with a stud on it for the battery case.
Checked on my photos it's not the rear engine mount triangle - I now think they were part of the rear number plate backing plate arrangement that is some sort of offcut from an alloy roofing section - there are not many other places left!
« Last Edit: September 13, 2021, 06:03:18 PM by Macabethiele (Ted) »
Offline Oz350Four
« Reply #6 on: September 21, 2021, 05:50:10 AM »
Ted, Oddjob may be onto something... check the plate which holds the instrument cluster to the headlight bracket and see if there are holes where the 2 posts should be..??  Just a thought.... [ Guests cannot view attachments ]
(Acknowledging screen shot taken from CMSNL website)
« Reply #7 on: September 21, 2021, 01:10:56 PM »
My Instrument bracket lugs are both in place.
« Last Edit: September 21, 2021, 02:28:17 PM by Macabethiele (Ted) »
