Author Topic: Rear indicator earth connections question?  (Read 1022 times)
Online McCabe-Thiele (Ted)
« on: September 13, 2021, 10:14:17 PM »
As you might expect both the earth terminals on my rear indicator brackets/ears are broken off whats the best method to work around this - I can't get enough heat on the bracket to make the solder run to attach a male spade.
1. Drill a small hole in the bracket and bolt on a terminal with a bolt head on the outside so it's not too obvious.
2. As 1 but pop rivet the connection
3. Run an earth from the lamp clamp into a dedicated earth. (You would see the wire)
3. Take the lamp apart and run an earth from the lamp unit.
My lamps are not the originals but the DS type cheaper units.
.rear indicator ears by Macabe Thiele, on Flickr
Offline Athame57
    • SeaWitch Artist
Re: Rear indicator earth connections question?
« Reply #1 on: September 14, 2021, 01:53:39 AM »
I might be considering buying new units, DSS has OE ones.
1978 CB400F2 called Elen.
« Reply #2 on: September 14, 2021, 08:11:50 AM »
I usually make up a lead with an eyelet that goes to the screw that holds the bulb carrier inside the light. I usually run extra earths to a lot of the components like that, bad earths are one of the biggest causes of breakdown on these old bikes. Corroded joints to the frame don't pass electricity as well as a direct cable.
Offline Seabeowner
« Reply #3 on: September 14, 2021, 08:24:43 AM »
500s had a ring terminal that attached to the bolt that clamps the indicator to the stem I think but I have later indicators (marked Stanley) that have an integral earth wire.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #4 on: September 14, 2021, 08:33:37 AM »
Dont remember any seperate earth wires on Honda indicators
« Reply #5 on: September 14, 2021, 10:08:13 AM »
The DS ones are £42 each - not sure they have the connection as it's not shown in the parts photo - that would be a last resort
« Reply #6 on: September 14, 2021, 10:56:36 AM »
It's a very simple fix Ted, just a short length of wire and a couple of connectors.
Offline wildtapholer
« Reply #7 on: September 14, 2021, 10:59:45 AM »
[I've done exactly the same when I refitted new front indicators I had a earth problem no matter what I did I couldn't get them to earth properly so ran a wire from inside each front indicator to chassis and problem solved./quote]
« Reply #8 on: September 14, 2021, 11:06:32 AM »
I do that on every bike I own. I usually end up running earth's to most of the components on the bike. Unless you do a full rebuild or deliberately clean the existing joints, you can't trust earth's off the frame on a 40 plus year old bike.
« Reply #9 on: September 14, 2021, 11:40:11 AM »
That thought had crossed my mind Roy last thing I want is unreliable lighting, like on fibreglass vehicles I will go for dedicated earth wires.
« Reply #10 on: September 14, 2021, 04:02:33 PM »
I've just opened up a DS cheaper option indicator & as you say there is a nice screw that attaches the bulb carrier perfect for my connections.
Need to find some wire next with the right earth colour.
« Reply #11 on: September 14, 2021, 04:18:56 PM »
Green should by easy
« Reply #12 on: September 14, 2021, 04:34:34 PM »
Here's one I made earlier. Actually it's on my CB350F that I restored a few years ago.
« Reply #13 on: September 14, 2021, 04:48:05 PM »
Would 1mm cable thin wall be the right sort or is that too thick is 0.35 or 0.5 better?
« Last Edit: September 14, 2021, 04:52:14 PM by Macabethiele (Ted) »
Offline hondarc166
« Reply #14 on: September 14, 2021, 05:06:17 PM »
   Try Vehicle wiring products for your cable and japanese connectors and insulation covers not to far from you ted at iikeston phone 01159305454 hope that helps
