Author Topic: Idle sticking at around 2500-3000  (Read 447 times)
Offline Dolomite_
« on: September 22, 2021, 08:07:24 PM »
When the bike is warm enough to have the choke off it idles fine at roughly 1200 but then when I rev to 6k and higher or after ive been riding for 10 mins or so the idle gets stuck at 2500-3000 even with the throttle fully closed, I'll have to blip the throttle to try to get it to settle back down and sometimes that doesn't work. When it does it while out for a ride as soon as I start letting the clutch out it goes right back down to near idle.
I had the carbs sonic cleaned and had new kits put in them so they are stock. I've just installed some new inlet intake rubber connectors and gaskets. But since I've already got the carbs off is there anything I can check in the carbs themselves to double check its nothing in them before I connect everything back up.
Re: Idle sticking at around 2500-3000
« Reply #1 on: September 22, 2021, 08:40:47 PM »
What make of kit we're they rebuilt with?
Offline Dolomite_
« Reply #2 on: September 22, 2021, 08:55:26 PM »
They were the davidsilver ones.
