Author Topic: Rear brake plate getting hot  (Read 417 times)
Offline billdn
« on: September 25, 2021, 10:14:38 AM »
Having replaced old brake linings with replacement from wemoto I've noticed that the outside of plate that holds them gets hot , by backing off nut on rod adjuster slightly it's not so bad but still gets warmish.  If I back it off anymore I'll have no rear brake! Any thoughts or is it just bedding in problem?
Online Bryanj
Re: Rear brake plate getting hot
« Reply #1 on: September 25, 2021, 10:17:03 AM »
Could be, try loosening the main axle the holding brake on to centralise shoes whilst tightening axle. There isnt a lot of clearance between plate and axle but it might help
