Author Topic: Sloppy clutch lever fix?  (Read 561 times)
« on: October 01, 2021, 04:00:32 PM »
There is a lot of sloppy up & down movement in my handlebar clutch lever - I've removed the pivot - it looks as if the wear is split between the lever & the pin.
There is also the wear to consider on the base unit itself where the lever / pin fits.
What's the best fix is it new lever & pin?
I do not have the machine tools to fit a brass insert in the old lever?
Re: Sloppy clutch lever fix?
« Reply #1 on: October 01, 2021, 04:02:47 PM »
It should have an anti rattle sleeve fitted around the pin Ted, do you have that part?
« Reply #2 on: October 01, 2021, 05:18:23 PM »
Nothing between the pin and the lever just a lock nut at the end - looked at the parts book but can't see the item or part number?
So that's a no I haven't
« Reply #3 on: October 01, 2021, 05:27:38 PM »
I may have led you up the garden path Ted. The anti rattle sleeve is on the brake lever...... Sorry 🙁🙁🙁🙁🙁🙁
« Reply #4 on: October 01, 2021, 06:10:07 PM »
I've priced up the clutch lever & pivot pin not daft money £17.76 for both plus P&P so will save up some more items I'm bound to need.
