Author Topic: Brake master cylinder.  (Read 968 times)
« on: October 05, 2021, 07:35:06 PM »
To paint or not to paint? I know these were not originally painted, don’t know what type of coating they had, but was thinking of painting in a satin finish, or just leave in it’s faded state. Already fitted new seal kit.
1978 Honda CB550K3.
Offline SumpMagnet
Re: Brake master cylinder.
« Reply #1 on: October 05, 2021, 08:30:23 PM »
I went through the same dilemma.
I opted to paint...but the risk then, of course, is getting brake fluid on the paint, as it will likely do a good job of taking it off.
CB750F2 - in pieces
« Reply #2 on: October 05, 2021, 08:33:25 PM »
Originally anodised
« Reply #3 on: October 05, 2021, 08:44:08 PM »
Thanks guys, next question is this being quite a simple brake system will it work with Dot5 silicon based brake fluid, don’t think it has the paint stripping qualities.
1978 Honda CB550K3.
« Reply #4 on: October 05, 2021, 09:37:38 PM »
It will if you have replaced all the seals and cleaned out all the pipework, reservoirs etc.
I have been told that whilst dot5 dont absorb water it does boil at a lower temp, never tried it so cant confirm that
« Reply #5 on: October 05, 2021, 10:09:27 PM »
All seals replaced and new brake pipes, so no traces of old fluid within system Bryan.
1978 Honda CB550K3.
« Reply #6 on: October 06, 2021, 01:05:00 PM »
Dot 4 & 5 are compatible so won't give you any realistic problems as seal compatibility exists between them.
Apart from being less corrosive for 5 I understand it as Bryan put,  that it doesn't effectively absorb water.
It's a odd situation though as Dot 4 holds water in suspension,  and so reduces boiling point as %i ncreases. The same water ingress to Dot 5 effectively drops to the lowest point of the system IF it were to get into the system in the same fashion.  This would also reduce effectiveness in a similar fashion.
Characteristic of bike systems though with a "bladder" type seal in master cylinder, they have very very small potential ingress of water to the effectively closed system and so doesn't really have to be considered in a normal service schedule. Nothing really to worry about if all components are to specification and working properly.
Incompatibility generally in brake systems comes from those using mineral oil as the seal specification are different to the Dot type systems.
« Reply #7 on: October 06, 2021, 02:09:19 PM »
Don't bother trying to paint the master cylinder as being anodised the paint won't stick even if you use a primer and it will craze before flaking off. Ask me how I know :-[
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline sye
« Reply #8 on: October 06, 2021, 02:14:01 PM »
I painted mine just fine. Use a dremel wire brush to remove the old finish and prime with etch primer. Top coat in satin black, job done.
Offline Seabeowner
« Reply #9 on: October 06, 2021, 06:37:39 PM »
Dot 5 fluid is more compressible than 4 or 5.1. Don't know how much difference that makes on a small system. Bought some a while back and not tried it. And not that it worries our old machines it is not recommended for ABS as far as I know.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline cbxman
« Reply #10 on: October 20, 2021, 11:37:18 AM »
Hi John,
I have had DOT5 in my CBX, front and rear, for 20 years after a full strip and rebuild and have not touched the brakes since.  Japanese bikes tend to be OK with Silicon.  I believe that Italian bikes are not compatible, but that is old information.  Things may have moved on in that regard.
As mentioned before, Just make sure every part and pipe is cleaned and change all the rubber parts together.  No problem.
Cheers,
Jerry
CB750 K1 1971 Wisconsin, USA
Suzuki GT550 J 1972 Michigan USA
CB360 G5 1975 UK
CBX1000 A 1980 (European Direct Sales)
CB1300 A5, 2005 UK
Offline Yoshi823
  • Biker to the bone...
« Reply #11 on: October 25, 2021, 09:20:41 PM »
DoT 4 and 5 are not compatible. It is DoT 5.1 which is.
I used DoT 5 back in the early '80s for my Honda CB750F2 Special & never had any problems. It did need very careful bleeding as tiny air bubbles would compress under braking if not bled successfully.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
« Reply #12 on: October 26, 2021, 10:53:56 AM »
Yep, you're right and I missed the  .1 there  :-[
It's even written on the cap of systems I'm currently working with
Albeit on mountain bike hydraulic brakes.
