Author Topic: 71 advance/retard mechanism  (Read 815 times)
Offline Popstar
« on: October 27, 2021, 03:10:14 PM »
Hello I’m just about to strip my 71 advance and retard mechanism and I’ve noted that there is an index mark on the outside of the central cam,Should the index mark lineup with the timing mark(hole) indicated by the Biro pen on the right hand side of the plate or as close to it as possible, also does anyone notice anything out of the ordinary on this advance and retard unit it is the number 323 which I believe is correct for the 71 model.
« Last Edit: October 27, 2021, 06:48:28 PM by Popstar »
Re: 71 advance/retard mechanism
« Reply #1 on: October 27, 2021, 03:20:13 PM »
It can only go one way for it to function correctly.
« Reply #2 on: October 27, 2021, 05:38:52 PM »
As above description,  it can fit two ways with the right way firing all of the cylinders correctly at TDC, the other assembly fires all the cylinders at BDC and so won't start.
It's only a case of removal and refit the opposite if you did get it wrong, so not a massive show stopper.
« Reply #3 on: October 27, 2021, 05:43:25 PM »
Or simply swap the blue and yellow wires.
Offline Popstar
« Reply #4 on: October 27, 2021, 06:31:00 PM »
Yes it is running like a dog however that may be something else i need to look at if the above photo is correct.
« Reply #5 on: October 27, 2021, 06:38:41 PM »
If it was switched it will be 180 degrees out and you may get a "phut" or phut-all  ;D if the ignition will fire any mixture with the pistons at the bottom and some valves open.
Something else must be wrong if it's running at all.
« Reply #6 on: October 27, 2021, 06:56:58 PM »
Just so happens Graham has both that I can photograph
Early type, correct orientation
Later type, correct orientation
The earlier type doesn't suit electronic ignition.
Online Bryanj
« Reply #7 on: October 27, 2021, 07:31:38 PM »
If it runs like a dog recheck the points gap(14 thou) and timing
Offline Popstar
« Reply #8 on: October 27, 2021, 07:39:41 PM »
Thanks mine is clearly out in comparison to the one pictured.
« Reply #9 on: October 27, 2021, 07:50:59 PM »
Also check the wires to the coils for colour as someone may have swapped those to correct an assembly error already (if the cam is in the opposite position, then swapping the wires flips the coils back correctly) meaning it could have two errors there already but will still run.
« Reply #10 on: October 27, 2021, 08:52:47 PM »
 :o :o :o :o
