Author Topic: Tank derust advice please.  (Read 1878 times)
« on: November 03, 2021, 01:53:48 PM »
I’m just seeking some advice on my tank prep please.
The plan is:
Currently added 5 litres of acetone and two handfuls of 10mm pea gravel. Soaked for 4 days with regular agitation.
Then drain and add 20 litres of DEOX-C made up with boiled hot TAP WATER to filler neck. Or should this be de-ionised water? The instructions don’t say.
Leave for 48 hours or so with regular agitation then drain
Rinse with 5 litres of deionised water and dry with a heat gun or hair dryer.
Rinse with a few litres of diesel.
Fill to brim with petrol
Install a line filter and go for it?
Thanks in advance.
Offline mickwinf
Re: Tank derust advice please.
« Reply #1 on: November 03, 2021, 03:34:53 PM »
I have had these problems in the past, most of the de rust methods work but in my case it was flash rusting afterwards that was the problem. I tried various methods from this forum and other sources but it kept on rusting until i tried nurse Julies tip of rinsing with de ionised water then as you suggest dried it out with a heat gun, which takes ages to get completely dry. Then swill with diesel, and that's how my spare tank is at the moment. So i think your method is sound, go for it!
« Reply #2 on: November 03, 2021, 03:38:58 PM »
I did the gravel agitation then I used Evaporust - not cheap but it works by breaking down the chemical bond between the steel and the iron oxide (rust)- I used a large bottle brush to help it along periodically - a few days later & the innards looked like new steel - flushed out with petrol / oil mix. Fitted a line filter.
I use Evaporust to clean all sorts of nuts, bolts, washers etc it does what it says on the tin. Thick rust deposits need a wire brush or similat to speed up the process. I keep a 5 Litre can in stock - you can keep on using the old Evaporust until it's spent. Bits like long engine mounting bolts I will leave in a used Evaporust bath for a weel or two. Only surface I have found that it has a strange effect on was a slightly rusty gudgeon pin - it turned that particular metal almost black so be  carefull with that type of steel.
Not tried DEOX-C as not aware of it but might be just as effective as Evaporust.
« Last Edit: November 03, 2021, 03:41:51 PM by Macabethiele (Ted) »
« Reply #3 on: November 03, 2021, 04:32:05 PM »
Ted.
I’m using DEOX-C filled to the tank neck. Did you fill to the tank neck with Evaporust?
« Reply #4 on: November 03, 2021, 05:08:41 PM »
I ran 5 litres of hydrochloric acid into it, swish about for 5 mins, washed with deionised water, dried with heat gun, swilled with diesel.
Spotless and clean with no return of flash rust at all.and its been sitting empty for 7 eeks whilst its been painted!  Crack on Phil ;)
« Reply #5 on: November 03, 2021, 05:21:15 PM »
Ted.
I was too tight at the time to fill to the neck -I put 10 Litres in the tank then lay it on either side eventually putting a plastic bag type seal over the filler cap and leaving it upside down. It weeped into a catch tray a tad but didn't loose the Evaporust.
« Last Edit: November 04, 2021, 11:21:56 AM by Macabethiele (Ted) »
« Reply #6 on: November 03, 2021, 05:22:49 PM »
I’m a fiscally challenged Yorkshire type so will adopt a similar, value added approach ;D
« Reply #7 on: November 03, 2021, 05:55:43 PM »
Give over, yer making me cry ;D
You've just had a stack of Timmy Taylor's vouchers off me, get on ;D ;D ;D
« Reply #8 on: November 03, 2021, 06:05:02 PM »
Already drunk that. 8)
« Reply #9 on: November 03, 2021, 06:35:14 PM »
 ;D ;D Good boy 8)
 ;D ;D ;D ;)
« Reply #10 on: November 03, 2021, 08:54:52 PM »
I wonder what deionised water is. Demineralized?
« Reply #11 on: November 03, 2021, 09:06:26 PM »
It’s £2.50, for 5 litres at Asda. ;D
« Reply #12 on: November 04, 2021, 01:49:31 AM »
same stuff
« Reply #13 on: November 04, 2021, 08:19:33 AM »
Thanks, so it is the same water for in a battery when level has dropped.
« Reply #14 on: November 04, 2021, 08:21:58 AM »
That’s right. Good stuff if the quality is good.
