Author Topic: The rebirth of Lazarus  (Read 58482 times)
Offline davidcumbria
Re: The rebirth of Lazarus
« Reply #405 on: April 21, 2024, 07:38:03 AM »
Mine are middle notch which is what the often posted chart says.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
Offline mickwinf
« Reply #406 on: April 21, 2024, 09:14:29 AM »
OK will try them in centre groove, thanks all. I must admit I am not enjoying this snagging process as I have not been able to have a proper ride yet. Hopefully get there soon.
Offline mickwinf
« Reply #407 on: May 11, 2024, 03:39:38 PM »
had a little time today as Luna the dog is recovering well from her operation and can be left unsupervised for a while. I decided to replace the clutch plates with new EBC items and also changed the springs for some H/D ones I had. Snag is I thought I had a spare gasket but that is a 550 and is slightly different. the old one would probably go again but dont want to do the job again. I have had the carbs apart and put the needle clip in the centre groove and made sure things were clean in there, once the clutch is back together will try it out and report back.
Offline mickwinf
« Reply #408 on: May 19, 2024, 06:22:16 PM »
had a chance to try a ride, only about 10 miles but a big improvement on before. the big flat spot is much reduced since changing the needle clip position and the clutch also feels better. A weird thing happens though when i open the throttle to accelerate It sometimes snatches as if i had momentarily pulled the clutch in, strange, and carbs still need setting better as get a hanging idle sometimes. At least I had an enjoyable ride with a reasonable chance of getting home with no unplanned stops!
