Author Topic: The rebirth of Lazarus  (Read 66613 times)
Offline mickwinf
Re: The rebirth of Lazarus
« Reply #390 on: April 01, 2024, 11:27:43 PM »
I did wonder about the adjuster, will check it out, cheers Bryan
« Reply #391 on: April 02, 2024, 12:00:47 AM »
They can crack and bind, the outer that is
Offline mickwinf
« Reply #392 on: April 07, 2024, 04:39:20 PM »
Still having issues with the clutch, slips badly if i feed the gas in too quick. stripped the clutch down and does not seem bad as in the plates not too thin. However the springs are longer than the manual states, but would that make it slip? I would have thought it would be the opposite. I do have another clutch I can try, and that has the shorter springs. At least I had a ride out and got home without an unplanned stop.
« Reply #393 on: April 07, 2024, 06:00:38 PM »
My original 500 used to slip like buggery on take off if useing a handfull of throttle taking several hundred yards(old english measurment) before stopping, never wore out and gave up worrying about it
« Reply #394 on: April 08, 2024, 08:35:55 AM »
Doesn’t help when trying to wheelie!😂
1978 Honda CB550K3.
« Reply #395 on: April 08, 2024, 08:58:07 AM »
Never managed a wheelie on the 500, but i was 21 stone at the time!
« Reply #396 on: April 08, 2024, 07:56:36 PM »
More than happy with both wheels firmly on the ground these days!😁
1978 Honda CB550K3.
Offline mickwinf
« Reply #397 on: April 12, 2024, 05:14:50 PM »
Still having issues. I put another clutch in and it is better but still seems to slip at higher revs. It's adjusted correctly and works smoothly. I did replace the springs with the correct length as the originals were extra long. Would using longer springs make it less likely to slip? Cable is new and correctly routed. Also not running right, when pulling away from a standstill it has a bad flat spot and will almost stall unless I give it loads of revs. Had a quick look at the plugs and very sooty. Carbs have been cleaned and synchronised.  Engine sounds a little flat when accelerating, not sure what to do next.
« Reply #398 on: April 12, 2024, 06:25:02 PM »
Points gap and timing first
Offline davidcumbria
« Reply #399 on: April 12, 2024, 07:58:10 PM »
I managed to get rid of that pull away bogging on mine by leaning off the air screws.
Offline mickwinf
« Reply #400 on: April 12, 2024, 08:31:17 PM »
Will re check timing but was spot on, will keep looking.
« Reply #401 on: April 12, 2024, 08:55:16 PM »
From the plug colour it does seem like its possibly rich enough to knock the edge off response and crispy-ness.
Worthwhile turning the idle adjust screws out half turn ...... to judge if there's significant change or not .... as experiment and investigate evaluation.
Quick and easy to assess effect, free too  :)
Offline mickwinf
« Reply #402 on: April 20, 2024, 05:01:50 PM »
so I have gone back to basics, timing is perfect with new Honda points, and reset the valve clearances. There is an occasional spit through the exhaust so I have taken the carbs off to clean again and check float heights. only done one carb up to now, but float was wrong and also the needle was set in the second to bottom groove, am I correct it should be second from the top? that would explain the richness. Carbs are 627b mains 100 slow 40s.
« Reply #403 on: April 20, 2024, 07:26:19 PM »
I seem to remember middle notch for needle which is 3rd from either end
« Reply #404 on: April 20, 2024, 09:09:41 PM »
Both my 400 & 500 needle clip is in the middle position 3 counting from either end.
