Author Topic: What would you do…..?  (Read 1941 times)
Re: What would you do…..?
« Reply #15 on: November 30, 2021, 06:35:02 PM »
Head Up Display clocks in the seventies too?...
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #16 on: January 17, 2022, 05:08:48 PM »
Think that you will find that because the UK continued with the K2 model until the K6 arrived, that from around 72 to 75/6 all UK bikes would have had frame numbers in the 20******** range and as such the engine No's would have been in the 20********* for 72 but in 73 the engine No's would have changed to 22****** series in 74 23******* etc.
So you need to check what year the bike was first registered as you may well find that it has the correct engine and frame No's for a UK bike of that year.
I'm picking up on this just now, after a long absence, because I have the same thing: Frame - 208**** and engine - 231****
When I started my rebuild I used a K2 parts book, out of ignorance, but later realised I should have been using a K4 engine parts book, or should I?
Or should I use a K4 parts book for both frame and engine?
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
CB450 K1 - A work in progress.
« Reply #17 on: January 17, 2022, 05:53:39 PM »
UK K2 parts book taking note of changes by engine No
Offline SeanFD
« Reply #18 on: January 19, 2022, 10:27:27 AM »
Thanks Brian
I'm happy now as that's, in fact, what I did.  :)
Sean
