Author Topic: Plastic throttle tube.  (Read 524 times)
« on: December 21, 2021, 11:45:13 AM »
Quick question! Lube or no lube? Maybe a little on the cable end but not on the bars? I’ve not had any bother in the past but just wondered about the correct or recommended application.
1978 Honda CB550K3.
Re: Plastic throttle tube.
« Reply #1 on: December 21, 2021, 12:13:11 PM »
I've always put a smear of light oil on the bar, not sure if it's necessary, but never caused a problem.
« Reply #2 on: December 21, 2021, 01:06:04 PM »
Always lube the bars myself. Usually silicon grease or oil.
« Reply #3 on: December 21, 2021, 06:18:58 PM »
I used Silicone Spray lubricant after thorough cleaning.
I use silicone spray instead of grease on my garage door mechanism as it does seem to attract the dirt & clog like normal oils & grease.
« Last Edit: December 21, 2021, 06:22:32 PM by McCabe-Thiele (Ted) »
« Reply #4 on: December 21, 2021, 10:50:44 PM »
Thanks guys, I have fitted using silicon spray on bar and lithium grease on cable end of tube.
1978 Honda CB550K3.
