Author Topic: Float Height Anomaly  (Read 673 times)
Offline Dave
« on: December 21, 2021, 07:30:14 PM »
I'm trying to adjust the float height. As you can see with the attached images, one side is set perfectly at 21mm (400F). However, when I check the other side there is a gap of about 1 and a bit mm. Laying the float on a flat surface shows no obvious twists or distortions.
I'm not sure what I should do next...
Dave
Re: Float Height Anomaly
« Reply #1 on: December 21, 2021, 07:32:58 PM »
Just push that side of the arm up a tad, or push the other side of the arm down a tad (do this with the float removed) . There is a twist or bend there somewhere.
« Last Edit: December 21, 2021, 07:34:51 PM by Nurse Julie »
Offline allankelly1
« Reply #2 on: December 21, 2021, 07:35:51 PM »
Yes I had this on two of my carbs
Like Julie said  they  are easy to bend /twist on the brass arm if needed but just be gentle with it
Best wishes Al
Offline Dave
« Reply #3 on: December 21, 2021, 08:27:14 PM »
Thanks for the feedback. Appreciated!
Yes Julie, definitely!! I'll let you know how I get on...
Thanks Al, I have exactly the same situation.  I don't feel so bad now ;-)
Offline allankelly1
« Reply #4 on: December 21, 2021, 08:30:05 PM »
No problem
To help I made up a float height gauge on my 3d printer to check that both floats are level be easy to copy with a piece of card or plastic
Made life so much easier
Best wishes Al
« Last Edit: December 21, 2021, 09:03:57 PM by allankelly1 »
