Author Topic: Motad exhuast mounting brackets on a 400/4  (Read 2723 times)
« on: January 01, 2022, 10:22:01 PM »
Not sure if anyone here might have a picture of the correct rear silencer bracket arrangement for the Motad system?
My bracket uses just one bolt on the rearmost frame mounting and looks a bit wrong somehow - not tried to fit it back on yet but the original fitting was under a lot of tension.
Are there any  decent off the shelf adjustable brackets available?
I have the original front pipes that are in good condition asside from the pipes being a tad rusted into the 4 into 1 part so might have to go for that and a new silencer otherwise.
Offline allankelly1
Re: Motad exhuast mounting brackets on a 400/4
« Reply #1 on: January 01, 2022, 10:46:15 PM »
Hi Ted
Happy new year
Do these help?
It’s all I have of the bike before I replaced the Motad fie Delkevic
Best wishes Al
« Reply #2 on: January 02, 2022, 03:00:42 AM »
Thanks Allan zooming in on the second photo I think I have a similar looking bracket that came in a box of oddments with the bike - might actually be the original hangar part - couldn't find it in the parts manual when I looked.
« Reply #3 on: January 02, 2022, 08:58:56 AM »
Although knackered Ted, I have a complete system that I took off Chewy, out on the scrap pile. As soon as I'm'home I'll bob out and have a look and see if  I can get you some shots if I can and if you still need them.
Might even have the brackets and fitting kitknocking about if you cant find yours mate. I'll be backabout 1pm so I'll have a look then if you've not already sorted it.
« Reply #4 on: January 02, 2022, 12:04:52 PM »
Thanks Roo I've just been off to local Covid place to get our PCR test as we have both been quite ill since Christmas Eve mainly feeling washed out, no appetite with bad coughs. Only managing a few hours sleep a day due to cough - lateral flow test negative so might just be a winter flu even though we have had flu jabs.
« Reply #5 on: January 02, 2022, 12:22:42 PM »
Ted, my wife who has me has had that cough since early november
« Reply #6 on: January 02, 2022, 12:32:38 PM »
Good move on the PCR, Ted. I had exactly the same symptoms. Interestingly I tested negative on three consecutive LF tests over a 48 hour period. I tested ‘positive’ on the PCR.
Offline Deano400
« Reply #7 on: January 02, 2022, 12:52:19 PM »
Ted, my son had symptoms and did LFTs 3 days running which were negative. Had a PCR on the day of his 3rd negative LFT and the PCR came back positive.
« Reply #8 on: January 02, 2022, 02:47:45 PM »
First photo is the bracket I took off single bolt hole was on the rearmost frame hanger lug.
IMG_20220102_141100 by Macabe Thiele, on Flickr
This is the plate from my bit box I have undone the captive bolts that have steel spacers for the short plate - the captive bolts are spaced as per the rear two frame hanger holes on both sets of holes - there are two holes not shown on the bottom where it has a 90 deg bend to attach to the silencer.
IMG_20220102_141117 by Macabe Thiele, on Flickr
« Reply #9 on: January 02, 2022, 02:57:45 PM »
Just got home, I'll have a look in a bit. Sorry youre feeling a but crap buddy. Good move on the PCR's though.
« Reply #10 on: January 02, 2022, 08:36:34 PM »
Ted, the main bracket in the bottom photo looks like the correct one for your 400 but I don't recognise the rectangular plate with 4 bolts.
« Last Edit: January 03, 2022, 05:40:55 PM by taysidedragon »
« Reply #11 on: January 02, 2022, 09:09:10 PM »
Ted, the main bracket looks like the correct one for your 400 but I don't recognise the rectangular plate with 4 bolts.
I've removed the rectangular plate as it seems a bit ott looks just like Allan's mounting in his second photo with it removed.
« Last Edit: January 03, 2022, 12:00:37 AM by McCabe-Thiele (Ted) »
Offline rosco
« Reply #12 on: January 03, 2022, 03:25:24 PM »
Hi Ted
        Just checked the bracket on my motad system and its the same as photo one  Two bolts to silencer  one bolt to frame
        Hope this helps
       Ross
« Reply #13 on: January 03, 2022, 09:55:11 PM »
Hi Ted
        Hope this helps
       Ross
Hi Ted, sorry for radio silence, had a hell of a day having diabetic issues and just haven't had the urge to get outside.......basically feeling really rough all last night and today topped off by the mother of all hypo's early this morning :-[. Needless to say I hobbled out half an hour ago tohave a look and indeed the fittings on whats left of mine are the same as yours and as described above.  If you need a spare bracket I'll post it up to you before the scrap pile gets liberated to the van back and the merchants.
« Reply #14 on: January 04, 2022, 12:39:14 AM »
PCR test negative for both of us.
