Author Topic: CB750 k3 pilot jets  (Read 540 times)
commando1954
CB750 k3 pilot jets
« on: January 09, 2022, 09:46:18 AM »
The pilot jets are about 1.1 mm inside diameter and when cleaning them noticed the diameter gets smaller in the middle. I have put a drill down by hand but it feels solid.Does anyone know if the diameter inside the jets gets smaller or should it be 1.1mm right through?
Re: CB750 k3 pilot jets
« Reply #1 on: January 09, 2022, 09:50:29 AM »
Yes, they get smaller. They have 'spiders' fitted inside them which gives turbulence to the flow of fuel. If you've pushed anything through the jets, the spiders will have been broken and the fuel flow pattern will not be correct.
commando1954
« Reply #2 on: January 09, 2022, 09:53:31 AM »
Thanks for your reply. I thought that might be the case.
