Author Topic: cb750 caliper rebuild kits  (Read 1175 times)
Offline haynes66
« on: January 18, 2022, 04:32:33 PM »
any recommendation for rebuild kits?  wemoto seem to be reasonable
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Re: cb750 caliper rebuild kits
« Reply #1 on: January 18, 2022, 05:56:57 PM »
be careful with after market rubber seal kits. I had no end of faff replacing pattern seals that were bought from Wemoto, they are crap quality and expand with fluid/moisture so that the pots will grab the discs, it actually warped one of my EBC discs on the VFR on the first use.
Replaced with Honda, and 10k miles later, no drama's.
If its brake seals, always go with Honda. Its a piece of mind thing also; it's for your brakes, you cant afford to comprimise on cost for the sake of a fiver if its brake components.
just sayin 8)
« Reply #2 on: January 18, 2022, 06:17:30 PM »
There is a firm in recomended, classic honda spares i think, who does stainless pistons with seals. I have fitted many of these and never had a problem but go direct its cheaper than fleabay. Also you MUST clean out the seal groove, especialy the corners perfectly with something like a dental pick, a wire brush in a dremel only polishes the crap and not remove it
Offline haynes66
« Reply #3 on: January 18, 2022, 09:01:20 PM »
thanks for that. so genuine DS ones would be best.  i have stainless pistons already so just need seals, boots, grease nipples etc
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline haynes66
« Reply #4 on: January 18, 2022, 09:33:03 PM »
DS caliper individual seals are £11.80!!   and i need 6.  i have emailed honda spares to see if they supply them so should hear something in the next few days
honda firestorm
YGS1 80cc yamaha
LE Velocette
« Reply #5 on: January 18, 2022, 10:05:08 PM »
You will get the seal at your local dealer and not pay postage!
45108300003
« Last Edit: January 18, 2022, 10:08:11 PM by Bryanj »
Offline haynes66
« Reply #6 on: January 18, 2022, 10:21:26 PM »
thanks bryan
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline haynes66
« Reply #7 on: January 22, 2022, 07:22:17 PM »
is that part number for the 78 f2 750?
honda firestorm
YGS1 80cc yamaha
LE Velocette
« Reply #8 on: January 22, 2022, 09:23:23 PM »
No only the early single caliper 750(and 500,400 etc)
F2 is 43209371006 and 45109371006 for the dust boot. The 371 means its same as a GL1000
« Last Edit: January 22, 2022, 09:28:44 PM by Bryanj »
Offline haynes66
« Reply #9 on: January 23, 2022, 08:37:26 AM »
thank you bryan, apparently that is the same part number for 1991 cbr600f2 rear caliper!. same price though...
honda firestorm
YGS1 80cc yamaha
LE Velocette
