Author Topic: The horn of death...  (Read 1066 times)
Online Athame57
    • SeaWitch Artist
« on: January 19, 2022, 01:52:16 PM »
Every time (well, twice in a row) I try to bib my hooter the main fuse blows.  :o  I can't say I've looked too hard yet, but has anyone else had this, or any ideas?
« Last Edit: January 19, 2022, 01:53:49 PM by Athame57 »
1978 CB400F2 called Elen.
Online Johnwebley
Re: The horn of death...
« Reply #1 on: January 19, 2022, 01:59:51 PM »
Any noise from the horn?
I would suggest you disconnect the wires from the horn,
Try a test bulb/lead,check the power lead to earth,
Connect the bulb between the 2 connectors, does the bulb light when you press the horn button?
Offline Alexrayz
  • 1976 CB400F- Just making my way through the galaxy
« Reply #2 on: January 19, 2022, 02:06:44 PM »
Maybe you could keep it as such and have an extra emergency off switch. Just need to holler whenever you need to.
No?
Ah well. Maybe your horn is just shorted out and needs replacement.
If it aint broken don't fix it
« Reply #3 on: January 19, 2022, 10:12:31 PM »
Certainly car horns can short out & blow a fuse.
« Last Edit: January 19, 2022, 10:45:49 PM by McCabe-Thiele (Ted) »
Offline TrickyMicky
« Reply #4 on: January 19, 2022, 11:34:46 PM »
Is it the standard horn fitted?  Some time back I fitted a pair of Fiamm type horns which really are effective, but the load was too much using the standard wiring, so I had to fit a relay. By all means check your current wiring and connections/earths, but if you get a chance, also look at the multi connector fitted behind the fuse holder. On mine, the internal blade connectors had all turned green and the main fuse was unable to cope with the extra load of pulling enough current through for high amp items.
« Reply #5 on: January 20, 2022, 06:44:16 PM »
“Horn of death” was that John Bindon or John Holmes’s?
« Reply #6 on: January 20, 2022, 06:46:06 PM »
Damn…wrong  forum again.
Online Athame57
    • SeaWitch Artist
« Reply #7 on: January 21, 2022, 12:33:59 PM »
It turned out to be a barred wire probably touching the frame, insulating tape for now, horn works without gazunking the electrics now!  ;D
Online Bryanj
« Reply #8 on: January 21, 2022, 03:05:27 PM »
Was it barred from pubs as well as clubs so got anoyed?
Online Athame57
    • SeaWitch Artist
« Reply #9 on: January 21, 2022, 06:04:44 PM »
ooops...a typoo, I meant barbed!
Online Bryanj
« Reply #10 on: January 21, 2022, 07:32:26 PM »
Cant complain, my dumfone does loads of them!
