Author Topic: Consensus on home plating.  (Read 3234 times)
Re: Consensus on home plating.
« Reply #15 on: January 26, 2022, 12:22:05 PM »
That's true Ash BUT you'd still have the chemicals etc AFTER plating that lot, you also forgot that Allenchrome gave you a decent price because you did a lot of the prep work for them, you also didn't factor in the petrol etc to take them there and back plus the time away from home. You then have to work out how much it would cost to replace small parts they may have lost but you didn't notice and you can do a thicker coat at home. Gateros told me that typcially they leave in for 15 mins when Gateros recommends 20 mins at the same ampage.
I'd agree though that that much is daunting to say the least, I'd imagine they will still do amounts like that but I wonder how much it would cost these days.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #16 on: January 26, 2022, 01:27:01 PM »
Ash,
I did find a very reliable local company when we lived in Southport who were not ripping me off but unfortunately with ever increasing 'elf an safety' demands they ceased trading.  Royal mail don't treat us any differently here in Orkney but some couriers either refuse to deliver or impose such eye-watering charges we in turn, refuse to use them, so it's a great advantage doing the stuff yourself and you can do small batches 'as and when' without having lots of stuff dismantled.
The actual prep time can be ignored if you always send stuff away ready prepped, so it's just the plating/rinsing/passivating time - when you can be doing something else anyway!
I wouldn't go back to risking sending small stuff away - obviously I still have to rely on others for Chrome plating.
Ian
« Reply #17 on: January 26, 2022, 01:42:51 PM »
Hmm ..being remote I can fully understand Ian's take on this and I admit that I did pretty good prep on the stuff I had done at Allenchrome. However, , he told me I didn't really need that level of prep due to their own prep that is part of their process. The travel factor cost doesn't come into it in my case as either my wife, my son or myself pass there at least once a week. Sadly, they won't now do a batch the size of the one in my pic. They need a full barrel, from a single customer, which is probably about 25 kilos. Julie will confirm this. My experiences on the chemicals is that they do get contaminated after quite a bit of plating (particularly by iron) and the anodes do get consumed. OK you can use hydrogen peroxide etc to restore but it's a load of messing about. Dont get me wrong I do agree with home plating as long as you have the time and patience but it's not particularly cheap...just the amount of Di water you use really adds up.
« Last Edit: January 26, 2022, 01:52:26 PM by AshimotoK0 »
« Reply #18 on: January 26, 2022, 01:46:02 PM »
Ok, so we all gang together, all members, we all throw our bits into a barrel until it's full, send it away and then sort out who's part is who's when they come back. Can't see any problems with that, can you?
« Reply #19 on: January 26, 2022, 01:59:04 PM »
I had a local plater who did industrial stuff that I used back in the 90's for the stuff on my 1100R/Phil Read Rep resto's. Provided I prepped the stuff, he was good and cheap. Went back to him several years ago and he'd moved to a more 'elf and safety' friendly unit (there's houses built on his old chemical leaky site!) and the cost had gone through the roof - probably H&S related and easier to make money on bigger batches
« Reply #20 on: January 26, 2022, 02:16:13 PM »
Yes  that would work I am sure  .. I am nearing the end of getting all of my parts for my bikes now though, so I would't be a contender. It's a shame as one more fairly  small batch at Allenchome would have seen me though.  Sadly, I have had to spend hours on end just doing a relatively small batch at home and I don't honestly  think the finish is quite as good as the pro's have done for me, particularly in terms of gold passivation.
« Reply #21 on: January 26, 2022, 02:28:30 PM »
In theory that sounds a good plan Ken. But, not every part can be barrel rolled, there are still lots of parts on our bikes that need to be wired, individually and its the labour involved in individual wiring that make the process expensive. Plus, you would never be able to return the correct, exact items, to the right owner. It would be a nightmare and if one persons prep is not as good as another, there is a big problem.
« Last Edit: January 26, 2022, 02:31:08 PM by Nurse Julie »
« Reply #22 on: January 26, 2022, 02:32:52 PM »
Yes Ash. Allenchrome will still plate for us but only if we take our usual 25kg up for plating, plus any bits that need wiring.
« Reply #23 on: January 26, 2022, 06:37:05 PM »
Actually Julie, that was a tongue in cheek post. It would never work, far too many parts look almost identical.
« Reply #24 on: January 26, 2022, 06:46:51 PM »
I really thought you were being serious Ken 😂😂😂.
« Reply #25 on: January 27, 2022, 07:49:39 AM »
Who supplies the barrel?
We could operate like a brand tub and you go in blind fold. You keep what you draw. Bit like buying of some unscrupulous eBay sellers. :)
Seriously though. Can anybody recommend an anodising company as I’m refurbing my tank badges.
« Reply #26 on: January 27, 2022, 12:59:25 PM »
According to anodisers, and I've talked to quite a few, only certain types of alloy can be anodised. I'm pretty certain tank badges are made of what Bryan calls pot metal, and thus can't be anodised.
I've got an experiment running next week where I'm testing 2 parts of my 500 in a special process, it's to see if they will stand up to it or disintegrate, if they do then no loss as they are spares, if they don't, oh my, watch this space, although it depends on cost I suppose.
Gateros do an anodising kit Phil, maybe worth a punt
