Author Topic: 750 K2 Strip & Rebuild - help please  (Read 22874 times)
Re: 750 K2 Strip & Rebuild - help please
« Reply #226 on: September 08, 2022, 03:05:33 PM »
Ed China used it on some semi exotic engine when he was on wheeler dealers
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #227 on: September 08, 2022, 10:09:44 PM »
Interesting. Particularly like the idea of higher BP and lowered operating pressures.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #228 on: September 12, 2022, 12:25:01 PM »
Another good day with the first start up after both carbs and engine fully stripped / rebuilt, and a new Boyer installed. Hooked the carbs up to a small tank, full choke, full throttle (my norm way of starting) and bloody hell, it started and ran immediately - within 1 sec of cranking. The only adjustment needed was about one turn of the master idle screw to get the idle about 1000 rpm.
Tomorrow will strobe set the Boyer to spec, apply decals and transfer tank / side panel badges to Menno’s freshly painted Body set.
Happy days….
« Reply #229 on: September 12, 2022, 01:31:02 PM »
Nice one.
Are you entering the bike for hill climbs  ;D ;D ;D ;D
« Reply #230 on: September 12, 2022, 02:40:15 PM »
No Ted… I hadn’t even considered it! My greatest concern would be dragging any small grit particles across the paintwork - how does this ‘system’ avoid such damage?
And what the hell is waterless coolant 😂? Intrigued…
Strangely enough the Waterless Cleaners are some sort of specialised sufactant probably using nano technology - when you spray on the cleaner it gets under any gritty particles and lubricates them so you can just wipe it off with a clean microfibre cloth without scratching the paintwork. That said I never used it on really muddy vehicles but worked well on normal summer & winter dirt. I will use it on my 400 to avoid introducing water. Aldi sold some a couple of years ago but it was not as good as the better ones.
It isn't cheap and you get what you pay for as there are a variety on the market - Iirc it's come from the USA. Lots of haters but ideal imho to clean little used bikes and avoiding rust.
When I was in the car trade a firm was selling it to some Mercedes retailers in the UK a few years back.
« Reply #231 on: September 12, 2022, 03:04:34 PM »
Formulation is around 85% ethylene glycol with other components to make the total mix. That's for the "Evans" titled product.
Ed China used on a Triumph Stag as I recall, which perennially suffered from cooling compromise for users insistent in running them without antifreeze or corrosion inhibiting mix. They have a bad reputation for such a simple anomaly that could have been competently avoided with decent coolant.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #232 on: September 13, 2022, 07:36:40 AM »
Tips please for getting a tank badge off the old K2 tank. The first popped off surprisingly easily; the second is anchored hard both ends. I’ve not yet squirted anything down the back, but given the expense of these things coupled with it being the 13th of the month 😂 I’ve walked away for now.
Ta
PS - I’ve bloody given up on pic orientation - figure it’s an iPad compatibly issue? Apologies…
« Reply #233 on: September 13, 2022, 10:37:42 AM »
Plastic knife or fishing line
« Reply #234 on: September 13, 2022, 12:25:02 PM »
Fishing line everytime, no chance of any dents or scratches. I even use it to cut off badges that are stuck on cars with foam sticky. A little sawing action and off they pop, and you can reuse them after, unlike when you try and lever them off.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #235 on: September 13, 2022, 12:51:07 PM »
Thanks Bryan/ Ken…. went the ‘line route, and as was about to give up due fear… it popped. Result!
Timed the Boyer Ignition today, and used #4 plug…. was amazed to see all 4 numbers hovering about the ADVANCE mark, ie 1/4 superimposed over 2/3. Scratched my head, only to read in the instructions…. “With this system all spark plugs spark at the same time, but only the cylinder under compression will fire”.
This means that my plugs will be firing 2x / revolution; twice as often as a 2 stroke! Anyways, does this directly translate into spark plug life being halved?
Cheers.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #236 on: September 14, 2022, 03:43:29 AM »
Servicing the fuel tap today, and was initially concerned how the feed tube slopes aft - thought I’d somehow bent it. (Never noticed this before!). This forced me to examine it a bit more closely, whereupon I noticed it was cracked over its full length. How on earth would that happen???
Anyways, as luck would have it I had brass tubing ‘in stock’ and got the old piece out (eventually) with side cutters at its base & levering. The replacement piece now happily in its new home…
« Reply #237 on: September 14, 2022, 04:22:29 AM »
Someone’s got the polishing bug
« Reply #238 on: September 14, 2022, 07:17:03 AM »
It splits when water collects and freezes, can happen to the ones in float bowls as well
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #239 on: September 16, 2022, 12:41:17 PM »
Putting new brake pads in today, and asking why there are no spring washers stipulated for the main caliper bolts (#22)? If there’s a couple of bolts I don’t wanna come undone these two would be toward the top of the list…
