Author Topic: 2 questions regarding exhaust and brake caliper  (Read 2847 times)
Offline horror
    • My art
« on: April 16, 2010, 10:51:15 AM »
Hi there
   The diaphragm in the front brake resevoir I have had turned to goo whilst the bike sat with no fluid in it. I think the goo has oozed into the master cylinder.
david silver seems to have 1 month waiting list on this part.
I whonder, does anybody know weather it's ok to use a front brake resevoir/lever/master cylinder off any other bike? For example a honda 200 benly.
Also, would an exhaust from a cb 500 or 550 fit onto the 400 four? or are the diameters and spacings different?
Cheers thanks
Offline matthewmosse
Re: 2 questions regarding exhaust and brake caliper
« Reply #1 on: April 16, 2010, 05:00:08 PM »
Hi, Not sure on the brake caliper / master cylinder side other than I know that the cylider needs to move a given quantity of fluid so using something off a similar bike could well work with the standard caliper. Personally I'd scan ebay and try breakers for the right part. Exhaust wise the spacing between ports is different, and I think the headers would be longer on a 500 as the engine is I'm pretty sure taller which would leave lots off messing at the least, not sure on diameter of pipes.
« Reply #2 on: April 16, 2010, 05:38:38 PM »
Piece you need is same on all the Honda fours so a used one should be about and no the 500/550 wont fit
Offline horror
    • My art
« Reply #3 on: April 16, 2010, 07:48:38 PM »
thanks
Offline Yoshi823
  • Biker to the bone...
« Reply #4 on: April 16, 2010, 08:43:29 PM »
I have spare diaphragms/bellows for sale...or do you want a complete master cylinder (minus lever) which I also have (
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline horror
    • My art
« Reply #5 on: April 17, 2010, 12:08:56 AM »
I got the diaphragm for mine from DS.
whilst gouging out the rubber goo I realised it has oozed into the cylinder. then the rubber boot part slit and came off.
I could get a repair kit for mine but thats 30 quid. then it's 30 quid for a complete aftermarket unit.
I know where I can get a 250 or 200 one for less and was hoping to do it on the dirt cheap.
I may come to you for that master cylinder, Does it have the guts in it?
