Author Topic: My next project  (Read 2445 times)
My next project
« on: February 07, 2022, 04:44:14 PM »
Hi All,
I've been thinking about what to do as a next project once I've finished rebuilding the Triton.
I'd like to do something a bit different to my usual of restoring a bike back to stock condition.
Having thought for a few months I'd like to build something a bit off the wall but not radical. To this end and having restored the CB250RSA previously that I've owned for 20+ years I thought I'd have a go at building a sleeper, in other words a CB500RSA. This uses a FT or XR SOHC engine slotted into a CB250RSA frame. It was a common mod back in the day to do this conversion.
My starting point will be to obtain a decent FT or XR engine and these are really hard to find. CB250RSA rolling chassis are much easier to find crashed, bashed, barn found or hacked about.
I've been looking on eBay for a while but engine wise there's nothing about other than bits such as crankcase halves etc
If anyone has a complete FT or XR500 engine laying around or knows someone who has can you let me know. I don't expect it to be perfect, I'd be stripping it down anyway but as long as the cam and head bearings are ok and no broken fins I'd be happy😁
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Rozabikes Tim
Re: My next project
« Reply #1 on: February 07, 2022, 05:47:21 PM »
Hi Dave
Have you considered SLR 650 / dominator  motor - same base engine I think?
I was looking at building an FT based flatracker and then hit on the idea of SLR. I actually have a motor (not for sale) but if you want any dimensions.....? I think the Lecky start was more reliable on these too?
They do suffer cam issues too but opens the net out if this route works for you?
Re: My next project
« Reply #2 on: February 07, 2022, 06:03:24 PM »
BUilt a flat tracket fpor a pal last year froman SLR donor bujke.Brilliant engine and  do have a better starter but as a motor theyre brilliant and dead simple to work on.  Dirt cheap to get a complete bike too.
Re: My next project
« Reply #3 on: February 07, 2022, 06:18:51 PM »
Got any piccies of what you built out of interest?
Re: My next project
« Reply #4 on: February 07, 2022, 07:03:10 PM »
Yeah, they're on the phone and I can only do one at a time so bear with.
It was bought by a pal from a bloke in Abberdeen, who MUST have used it as a boat anchor as it was the rustiest bike I have ever worked on. Simbly knackered!
My pal finished it off when I came down to Bristol last year so these are a few of how dreadful it was  and a few of the process. The motor, however was fantastic and he didnt want to split it so I painted it complete in the garage. Not my preferred method but it came out reasonably well.
It had 17" rims off a donor in the pile and a shock off a 2001 Triumph T509 so we could rebuild it plus it had a remote reservoir as my pal's a fat git and he needed it! His name's Lard......... I kid you not, He needed it;D
It became a flat tracker as we had to cut so much knackered rusty subframe off it that it was the easiest option. It had a CG125 tank on it, Renthal bars, Yorkshire Tea tin battery box, brembo twin pots from a 1997 Ducati 748, bear trap pegs and moto gaget gubbins to fit. I left the project at that point and moved here. Ive not heard much about it for a while so I suspect it will be at the back of the shed lurking in the 'to finish' que. It ended up a build from what we could gather rather than what we could spend on. It appeared that as long as it had Honda on it, it would probably fit with minor nannying. It was a good chuckle through the first lock down.
Re: My next project
« Reply #5 on: February 07, 2022, 07:08:28 PM »
Pile of bits to start
Re: My next project
« Reply #6 on: February 07, 2022, 07:10:32 PM »
Re: My next project
« Reply #7 on: February 07, 2022, 07:11:36 PM »
Re: My next project
« Reply #8 on: February 07, 2022, 07:12:44 PM »
Re: My next project
« Reply #9 on: February 07, 2022, 07:13:59 PM »
Re: My next project
« Reply #10 on: February 07, 2022, 07:15:05 PM »
Re: My next project
« Reply #11 on: February 07, 2022, 07:16:41 PM »
Re: My next project
« Reply #12 on: February 07, 2022, 07:20:28 PM »
Re: My next project
« Reply #13 on: February 07, 2022, 07:21:07 PM »
I haven’t got any others on this phone but you get the gist. It was built for a giggle.
Re: My next project
« Reply #14 on: February 07, 2022, 08:20:19 PM »
This is what inspired me. FT500 based. Personally think the standard FT is pig ugly.
