Author Topic: F1 lumpy low speed running.  (Read 1724 times)
Offline Skoti
« on: April 21, 2010, 01:55:44 PM »
Sorry to keep posting as many questions, but this is the first F1 I've owned and I'm not sure what to expect of it.
At low speeds and around 2000rpm when riding through towns the motor feels lumpy, open the throttle a touch and it becomes smooth.
Is this normal   :-\
Skoti
1976 Honda CB750F1
Re: F1 lumpy low speed running.
« Reply #1 on: April 21, 2010, 02:04:02 PM »
No probably needs carb balance but do all the rest of the service items FIRST
Offline Skoti
« Reply #2 on: April 21, 2010, 03:15:06 PM »
Hi,
Yes has had new plugs and points fitted.
Timing done with strobe light.
Carbs removed and cleaned out and balanced with mercury gauges.
Valve clearances and cam chain adjusted.
New after market air filter fitted.
Air screws adjusted to 1 3/4 turns out.
Idles at 1000rpm when hot.
Only on very light load and small throttle openings the motor is lumpy and erratic.
I notice that spark plugs No 1 and 3 are a little sooty compared to spark plugs No 2 and 4. Do you think I should turn the air screws out a bit more on carbs No 1 and 3 and see what happens?  :-\
Skoti
1976 Honda CB750F1
« Reply #3 on: April 21, 2010, 06:30:02 PM »
Mine is not impressed at slow running so I just go down a gear or two, works OK then.
Den
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #4 on: April 21, 2010, 06:41:10 PM »
I would go back to balancing the carbs again, well worth investing in a kit. I had similar problems with my CB750 but it did sort out the low rev lumpy/chain snatch problem
Good luck
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline Skoti
« Reply #5 on: April 21, 2010, 06:56:09 PM »
Fixed  :)
Decided to screw out No 1 and 3 air screw an extra 1/4 turn. Just been for a road test and it's nice and smooth now at low speed/revs.
Removed the plugs again and they are more or less all the same colour.
Amazed at how such a small adjustment can make such a big difference.
Summary:-
Carbs No 2 and 4 air screws are 1 3/4 turns out. Carbs No 1 and 3 air screws are 2 turns out.
I'm aware the normal setting is around 1 turn out but I fitted an aftermarket air filter and then read some where that they are more restrictive that the genuine Honda filter.
Skoti
1976 Honda CB750F1
