Author Topic: cB400 left side handlebar switches wiring question?  (Read 1775 times)
« on: February 25, 2022, 02:43:47 PM »
The left side wiring loom from the switch that operates the Indicators, horn & headlamp beam has been messed with - it has the wrong sized male connectors so I am changing them to match my new loom. I suspect that the only female connector might be fitted  incorrecly but am not sure.
The loom wires are  the following colours,
Dark Blue (male)
Black/yellow trace (male)
Orange (male)
Grey (male)
White (male)
Light Blue (male
Light Green (female)
Can anyone please confirm if the one female connector on the light green wire is correct - the colour is somewhat faded.?
Re: cB400 left side handlebar switches wiring question?
« Reply #1 on: February 25, 2022, 04:19:03 PM »
By what i can remember Ted, the light green is a female (it's the horn wire). I'll see if I can find a pic somewhere on my PC
« Reply #2 on: February 25, 2022, 04:29:24 PM »
If the wire carries power it has a female connector on so that it gets a plastic sheath which prevents accidental grounding, if it's a return from the equipment it has a male. IIRC the light green wire connects to a black wire in the switch when the horn is pressed and black is power so the wire will be live so it will have a female connector. That will of course connect to a male from the horn and they'll be another wire going to ground from the horn. (dark green) or may be black with a green ring on it.
« Reply #3 on: February 25, 2022, 06:03:58 PM »
I think the early switch grounds the hornto the bars, you can tell which you have by looking at the horn.
If the thorn has a loop wire to ground the switch provides power, if it has a live wire with ignition o the switch grounds.
Offline smoothoperator
« Reply #4 on: February 25, 2022, 06:51:02 PM »
Not sure if this helps Ted but here is an early photo showing the wires from the loom to the horn. Light green goes to one of the horn connectors and the other wire from the horn goes to a loop connector that sits on the front coil long bolt next to the frame. They are the wires I am holding.
Steve
2017 Triumph Bonneville T100
« Reply #5 on: February 25, 2022, 08:19:31 PM »
Thanks for the input I guess the green female is correct I'll see how it pans out when I connect the battery next week.
Ameded update:-  I seem to have more than one version of the wiring circuit.
1) The light green female connector is live when the horn putton on the handle bars is depressed so this feeds the horn that is itself earthed to the frame by a second connection.
") Another wiring diaagram shows the horn fed with a black wire from the ignition then a light blue wire from the horn via the loom so the handle bar button earths the circuit.
They can't both be right?
« Last Edit: February 26, 2022, 02:09:26 PM by McCabe-Thiele (Ted) »
Offline ka-ja
  • ken
  • yoshi 460
« Reply #6 on: February 26, 2022, 03:30:26 PM »
The latter is correct for my 1976 F2 model, the button earths the horn, this was discussed several years ago on here, and I have an (ex-ebay) A3 size coloured diagram showing it
nice bike,nothing in the bank
« Reply #7 on: February 26, 2022, 03:38:03 PM »
There are 2 versions of the left hand switch Ted, one only has a horn button, that one earths the horn, the other has a pass/horn switch, you press for horn and push right for headlight flasher, this is the correct switch for the UK, the horn only is a US market switch, commonly found on imports. If you have the pass/horn it's option 1, if horn only it's option 2.
« Reply #8 on: February 26, 2022, 04:13:34 PM »
I only have a horn button like you no headlamp flasher - my bike has not been imported from the US it was registered new in the UK.
If Ken is right (he usually is) then at some time the switch unit has been changed for a US one, strange as both switchgears on the left & the right have matching faded patina.
« Last Edit: February 26, 2022, 04:23:07 PM by McCabe-Thiele (Ted) »
« Reply #9 on: February 26, 2022, 04:25:10 PM »
So you just have a Horn button like me no combined headlamp flasher ?
This might explain why the Horn was not on the bike when I bought it - also no mini wiring loom for the horn.
« Reply #10 on: February 26, 2022, 04:30:30 PM »
Here's a photo of Hetties left hand switch gear Ted. 1977 UK model.
« Reply #11 on: February 26, 2022, 04:46:05 PM »
Thanks Julie mine is not like that it's just a button like the starter.
Offline 400 Cafe Racer
« Reply #12 on: February 26, 2022, 06:33:25 PM »
Hi Ted,
Mine is the same as Julie's with the headlamp flasher, they have matching faded patina at the edges and look original. My bike is UK registered in 79 and late F2.
It seems you are well into the wiring now, when is launch day Ted ?   ;D ;D
All the best
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest    - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
« Reply #13 on: February 26, 2022, 06:42:03 PM »
Hi Ted,
All the best
Mine was registered March 1978 it seems to have had quite a few odd US parts fitted like the rear mudguard & now it seems some switch gear.
I'm thinking end of March early April  depending on the weather. I'm not re-painting the Tank & side panels until the back end of 2022 assuming it starts & runs OK for the summer.
Ted
« Reply #14 on: February 26, 2022, 07:27:34 PM »
Great stuff Ted,
Look forward to the launch, with all the love and care you have given her I am sure she will run like a clock after the usual Carb adjustments after initial settling in.
Cheers  ;D
