Author Topic: coils  (Read 4476 times)
Offline captaindonutbikes
coils
« on: April 29, 2010, 02:14:13 PM »
quicky to be sure.
thin fitting to live -  fatter fitting to negative
cb550k3 cafe
Offline totty
Re: coils
« Reply #1 on: April 29, 2010, 02:19:13 PM »
Are they from a Boyer kit ?
If they are then they should have + and - marked near the terminals.
Can you also post a pic of them mounted as I'm not really happy with how I've mounted mine.
Offline Yoshi823
  • Biker to the bone...
Re: coils
« Reply #2 on: April 30, 2010, 08:45:07 AM »
If there's no +ve or -ve marking, it dosn't really matter, as the primary/input circuit isn't polarity conscious. One side will have the +12v standing voltage, the other will be the switched input from the contact breakers.
http://en.wikipedia.org/wiki/Autotransformer
So the spade connectors are the low tension input, the output to the spark plugs is for the fatter connector.
« Last Edit: April 30, 2010, 08:46:54 AM by Yoshi823 »
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Re: coils
« Reply #3 on: April 30, 2010, 10:32:17 AM »
Tim, I was refering to the HT leads attaching to the coils.
fatter earthed cable end to negative output - thin live HT end fiitting to live output from the coils or does it not matter a toot ?
cb550k3 cafe
Re: coils
« Reply #4 on: April 30, 2010, 11:08:23 AM »
As its a Wasted Spark system with both plugs sparking together it dont matter
Re: coils
« Reply #5 on: April 30, 2010, 11:30:52 AM »
Thanks as always mr Bryan Sir!
cb550k3 cafe
Re: coils
« Reply #6 on: May 08, 2010, 02:14:08 PM »
Totty,
my Boyer coils mounting solution.
Bit of stainless plate cut to fit the kidney shape then cut a flap for the cdi to mount to.
rattle can black.
tidy.
cb550k3 cafe
Re: coils
« Reply #7 on: May 08, 2010, 02:28:19 PM »
Very neat and tidy, bet the paint dont stick to the stainless for long tho'
Re: coils
« Reply #8 on: May 09, 2010, 12:02:44 PM »
plasticote  ;)
cb550k3 cafe
Offline totty
Re: coils
« Reply #9 on: May 09, 2010, 03:44:31 PM »
That's a hell of allot better than mine, I might try something along those lines.
Allan
Offline florence
Re: coils
« Reply #10 on: May 11, 2010, 09:45:37 AM »
Do these coils work with points?  How much do they cost?
I like the look of them, it might be what I need on mine.  Whenever it rains my bike splutters along on about two cylinders until the heat from the engine dries out the wires, usually about three miles.   Very annoying.
Offline matthewmosse
Re: coils
« Reply #11 on: May 11, 2010, 02:03:53 PM »
I'd start with new plug caps if rain is causing spluttering. I think the coils in the pictures are ones for a boyer system, as I understand it boyer do several systems, I have a set that use the standard points but I think there are systems that replace the coils as well (basically electronic coils which are smaller and reconed to be better), I don't think the 2 types are interchangeable. Points coils are different ohmage or something. Coils from most points 12 volt bikes should work on 500's
Offline florence
Re: coils
« Reply #12 on: May 12, 2010, 09:46:08 AM »
Thanks Matthew, I will try that.  At the moment I have the whole lot covered, and I mean covered, with grease which improves it a little but maybe it is time for a new set of plug caps.  The main thing which has delayed me in this is the fact that one of the leads is rather short.  I need to find a long cap that will fit.  The other thing is I normally just put up with these problems until they become completely unbearable.
Recently, I managed to make enough room in my workshop to put my bike inside at night.  This seems to help a lot but strangeley the lichen growth on the frame is slowing down.  Poor lichens. :)
Back in the winter a friend who doesn't know me too well saw my bike outside my house.  He said; "Wow, I didn't know you had a bike, do you think you'll ever get it back on the road?"  I had not long come back from the shops on it.  He was amazed to discover that the engine was in fact still warm.  Leave all that polishing to those who enjoy it I say.
Sorry, I'm drifting.
Offline Yoshi823
Re: coils
« Reply #13 on: May 12, 2010, 02:42:58 PM »
I had a bad experience of plug caps back when I was riding in all weather commuting to Navy college. On my CB125s back in 1975 I had one of those metal shrouded caps that I didn't realise was the original. I can remember riding along the A2 on my way into college one morning, & when I put the indicators on in the pouring rain the bike staggered & jerked in unison. I tried the coil, the plug etc...because I didn't know any better. But one day I was reading Motorcycle Mechanics about a new range of plug caps from NGK which were waterproof...& for the sake of pennies compared to the cost of coils etc the bad weather problem was cured.
Yamaha R1 2001
Honda XR400R 1997
Honda CB125T2 1980
Re: coils
« Reply #14 on: May 12, 2010, 02:58:47 PM »
I have had 2 bikes in a row recently stagger to a halt with wet / old plug cap syndrome in even the mildest drizzle. I now have a small can of Wd40 as a standard part of the toolkit and new plug caps on the bike. My bikes also live outside these days and that's something I really must do something about, I used to keep them under a really basic tarp tent style shed supported on fenceposts and even that helped keep things like plug caps functioning well.
