Author Topic: Taper head bearings.  (Read 819 times)
« on: March 13, 2022, 09:24:37 AM »
Just removed the old head bearing ball races from the frame. On the lower one there is a round spacer underneath the bearing, does this stay in when fitting taper roller bearings or do I need to get it out (see photo). Also, which taper bearing goes to the bottom, thick or thin. And where do the sealing washers go.
You know, I have done this a dozen times and I cant for the life of me remember how they go. Memory must be failing along with the rest of me. If it needs to come out, I need to do it quick before it goes for powder coating.
« Last Edit: March 13, 2022, 09:26:09 AM by royhall »
Online Bryanj
Re: Taper head bearings.
« Reply #1 on: March 13, 2022, 12:31:33 PM »
There should not be any spacer in there just the shoulder the race goes up tp
« Reply #2 on: March 13, 2022, 12:46:20 PM »
I assume the larger of the two bearings goes in the bottom then Bryan. Is that spacer there just for the original loose ball race then.
« Last Edit: March 13, 2022, 12:48:25 PM by royhall »
Online Bryanj
« Reply #3 on: March 13, 2022, 03:17:12 PM »
Not supposed to be a spacer for any of the bearings mate, nothing in parts book
« Reply #4 on: March 13, 2022, 03:44:11 PM »
Spacer might be part of it having had aftermarket Bearings fitted.
« Reply #5 on: March 13, 2022, 06:46:05 PM »
They were the standard loose ball bearings.
Sent from my Pixel 6 using Tapatalk
« Reply #6 on: March 14, 2022, 09:20:13 AM »
I might have misunderstood you is the spacer on the forks side - does it form part of a seal of some sort?
