Author Topic: 400-4 engine racing  (Read 722 times)
Offline TOMMO.W
400-4 engine racing
« on: March 18, 2022, 08:02:10 PM »
Hi,
First ride out this year and the bike ran fine until 10 miles or so, then it felt as if the engine would not go back to tickover.
I am guessing that carbs are sticking perhaps due to getting hot.
Any suggestions of how to correct this?
Cheers Tom
Re: 400-4 engine racing
« Reply #1 on: March 18, 2022, 08:21:31 PM »
How high is it revving?
Does the 400 have push/pull cables?
It might have loosened up enabling the motor to spin more freely,
Or it could be an air leak in the induction area
« Reply #2 on: March 18, 2022, 09:51:22 PM »
Yes John, push pull cables.
Could be throttle cable adjustment nut at the carb end has come loose or the cable may have slipped out of the main channel on the big butterfly thingy on the top of the carb and has the carbs wedged open. Heat not usually a factor. It's probably just a mechanical part slippage or failure. That's if the revs stay up high and don't fluctuate. If the revs fluctuate up and down, regardless of throttle position, it's more than likely an air leak.
Offline TOMMO.W
« Reply #3 on: March 20, 2022, 09:55:33 AM »
Thanks for your suggestions. I bought the bike a short time ago so I am thinking that I will take the tank off and check carbs etc for any thing that doesnt seem correct.
Thanks Tom
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #4 on: March 20, 2022, 10:34:12 AM »
… if no luck check the advance / retard mechanism not sticking.
