Author Topic: CB550k1 US Import - UK registration  (Read 38188 times)
Offline juitz
« Reply #360 on: January 15, 2023, 09:00:56 AM »
This spark advancer unit I have and how it is installed.
It took a few goes, but in the end i managed to get the timing correct with a 0.3mm airgap. But I have no idea why?
« Last Edit: January 15, 2023, 12:19:43 PM by juitz »
Online McCabe-Thiele (Ted)
« Reply #361 on: January 15, 2023, 10:56:59 AM »
Tbh we've all had that experience I suspect.
My last similar issue was when the primary gear shaft would not fit into the second  bearing on the 400. For no discernible reason after 20 mins & a coffee break it just laughed at me and fitted.
Offline juitz
« Reply #362 on: January 22, 2023, 04:57:26 PM »
Hello all,
Engine rebuild is going but slowly. Unfortunately, house reno items are higher priority in the missus list of things to do.
Quick one for this week, as I can't find the assembly.
Which way does the neutral switch go on the shaft? Is this right way around?
« Reply #363 on: January 22, 2023, 05:17:41 PM »
Yes, The contact switch is normally at about 8 o'clock in neutral.
« Last Edit: January 22, 2023, 06:55:10 PM by Sesman »
« Reply #364 on: January 22, 2023, 05:29:43 PM »
There should be a peg on the back that locates in a slot in the end of the drum, i have some nos if its broken
« Reply #365 on: January 22, 2023, 06:57:20 PM »
Hey Bryanj, are those nos lotsa money? Asking as I had to repair mine.
« Reply #366 on: January 22, 2023, 09:02:21 PM »
I will sell them at what i paid so £5 plus post and i havent got loads plus no static parts as they all went
« Reply #367 on: January 23, 2023, 06:47:02 AM »
I’ll take one please.
« Reply #368 on: January 23, 2023, 07:22:19 AM »
If it's for a 500 I'll take one please Ken.👍
« Reply #369 on: January 23, 2023, 12:51:30 PM »
If it's for a 500 I'll take one please Bryan👍
« Reply #370 on: January 23, 2023, 03:46:07 PM »
Not wishing to take any of Bryans sales away but as these will eventually no longer be available I thought I'd mention it's possible to repair the thing. So long as you can make out where the lug used to be you can file the back of it and just leave that section alone. Eventually you'll have another lug where the old one used to be, it's only a type of Bakolite and is easy to file, thickness doesn't seem to matter as it's the brass/copper contact that does all the work and so long as you leave that alone it's all good. I've repaired a few doing just that.
Offline juitz
« Reply #371 on: January 24, 2023, 12:27:45 AM »
Thanks guys.
My unit looks ok incl. Lug on the back so will crack on 👍
Offline juitz
« Reply #372 on: January 30, 2023, 10:57:40 AM »
Morning!
I'm looking to fit the alternator harness, but have a question on the oil pump switch?
I think this is correct, but the elec drwg I think says B/R?
I did reference a photo from the stripdown, but this has the oil switch not connected
« Reply #373 on: January 30, 2023, 03:27:50 PM »
Blue/red is correct for oil pump switch. Very common to see them like that, tended to get trapped when putting the cover back on.
Offline juitz
« Reply #374 on: February 04, 2023, 03:14:00 PM »
Good Saturday to all,
Clutch lever - these are the positions I can move it, but I think it should be able to pivot around both sides of the marking on the case? Couldnt find a relevant section in the manual.
