Author Topic: CB550k1 US Import - UK registration  (Read 38008 times)
Offline juitz
« Reply #525 on: May 27, 2023, 09:03:10 AM »
/quote]
Circlip has come off Juitz,l as you suspected when I was telling Ted to make sure to fit a new one.
Yep, confirmed.Found these treasures in the bottom of the sump
This is sub-optimal. Aside from the pain in trying to get the assembly back in without removing the engine. Can I just leave it as is and only use electric start.
This feels like a "next winter" job [ Guests cannot view attachments ]
« Reply #526 on: May 27, 2023, 10:29:48 AM »
I would make sure you have all the washers as well. One might be in the ratchet end
kick start parts in order by Macabe Thiele, on Flickr
Offline juitz
« Reply #527 on: May 27, 2023, 11:01:24 AM »
Yeah, Def a problem here as I'm missing the slotted thrust washer between the pinion spring and ratchet. Gonna chech my assembly pics but was sure I did this correct.
« Reply #528 on: May 27, 2023, 12:31:09 PM »
The washer might still be on the shaft end inside with the bigger spring?
Pretty sure you can wiggle them off with a bit of patience - a magnet on a telescopic shaft  might help.
Can't see a problem in using it without the kick start mech in place - you could take the lever off to reduce weight etc.
« Last Edit: May 27, 2023, 12:43:09 PM by McCabe-Thiele (Ted) »
Offline juitz
« Reply #529 on: May 27, 2023, 01:14:01 PM »
Yeah found it stuck to the pinion gear.
But all back together now with new circlip. Works again 😄
Thanks again, help as always immensely appreciated 👍
« Reply #530 on: May 27, 2023, 01:16:36 PM »
If you did that through the sump you have passed your stage 1 Gynaecology practical exam.
Offline Matt_Harrington
« Reply #531 on: May 27, 2023, 01:42:26 PM »
 :D :D
Offline davidcumbria
« Reply #532 on: May 27, 2023, 04:33:25 PM »
Congratulations on not having to split the cases. What a nightmare. I’ve ordered two new circlips for the kickstart thanks to this forum. A very tricky job completed 👍
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
Offline juitz
« Reply #533 on: May 27, 2023, 04:49:11 PM »
Oh dear 😂😂
« Reply #534 on: May 27, 2023, 05:38:21 PM »
Stage 2 involves building the engine through the letter box. Challenging.
Offline juitz
« Reply #535 on: June 03, 2023, 07:22:02 PM »
Hey all, what is the petcock nut size for a cb550k1?
I think it's 18mm but the two I've purchased don't fit.
I could just buy an OE one but would prefer to save £20 😉
Or would one of these be ok to use? The body on mine is ok, it's got the dual output but the tube, orings and gauze are stuffed.
https://www.ebay.co.uk/itm/224064453335?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=_p-q3hvvQhS&sssrc=2349624&ssuid=eMi7QkCfTHq&var=&widget_ver=artemis&media=COPY
« Last Edit: June 04, 2023, 05:07:01 PM by juitz »
Offline juitz
« Reply #537 on: June 05, 2023, 09:11:25 PM »
This is what I’m thinking of for mine. Reckon it’s a 20 mm connection
https://www.amazon.com/CB400F-CB550F-CB550K-CB750F-CB750K/dp/B0B6F2CG8Y/ref=sr_1_1?crid=2G5O57QHYL1TP&keywords=CB550+tap+20mm&qid=1685863363&sprefix=cb550+tap+20mm%2Caps%2C196&sr=8-1
Cheers. Ended up getting one from 4into1 along with some new main jets. Cheaper option than new or the repair kit.
Offline juitz
« Reply #538 on: June 10, 2023, 03:55:54 PM »
Hey all!
Took my cb550 project bike out for its maiden ride today. Aside from the panicked moment I had when the bike sputtered and stopped, then realised I had previously turned off the petcock it went well.
Carbs need further tuning but I am hearing quite a distinct rattle sound at higher than 2000rpm. Varies if accelerating or not but it's there. It kinda sounds like a chain is rubbing? I have a new timing and cam chain and have adjusted the cam tensioner twice.
As I don't have a previous baseline, im not sure if this is normal? Anything else that I could be?
« Reply #539 on: June 10, 2023, 07:16:44 PM »
Do you have the updated valve cover with pegged rocker shafts ?
