Author Topic: Honda fuel pipe spring wrap 17531-377-000 what's its purpose?  (Read 697 times)
I was looking at the above part described as a "Heat Shield" for the fuel pipe - it got me thinking as to how it worked - being steel would it not attract the heat due to it's conductivity?
Mine is missing it got me thinking was this originally designed for the old clear plastic type fuel pipe to stop it going out of shape?
Is there a SS alternative on the market that anyone has used?
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Honda fuel pipe spring wrap 17531-377-000 what's its purpose?
« Reply #1 on: April 18, 2022, 11:55:48 AM »
Hi if it wasn’t described as a heat shield I would have guessed it’s to protect the pipe from rubbing on the top of #1 carb, albeit a low risk in the case of the modern pipe material.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline sye
« Reply #2 on: April 18, 2022, 12:30:44 PM »
The heat trapped in the coil will dissipate very quickly due to it's design rather than be absorbed by the dense rubber underneath.
« Reply #3 on: April 18, 2022, 12:34:10 PM »
Honda NEVER used the crappy clear plastic fuel pipe from the factory
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #4 on: April 18, 2022, 12:43:17 PM »
My guess would be to minimise any chance of Vapour Lock which is basically heat from a shut-down engine vaporising fuel in the lines causing subsequent starting problems. Fairly well understood within the light aviation fraternity.
An explanation here:
https://www.carparts.com/blog/vapor-lock-symptoms-causes-and-solutions/
Notably, towards the end of the explanation it says… “You might also consider covering the fuel lines and the carburetor in heat shields”, which probably explains the spring shield.
« Last Edit: April 18, 2022, 01:22:13 PM by Lobo »
