Author Topic: 400/4 build. Paused due to other commitments. But starting up again  (Read 24439 times)
Offline Deano400
Re: 400/4 build. Paused due to other commitments. But starting up again
« Reply #465 on: September 26, 2023, 08:19:08 PM »
Found a copy on my laptop.
Offline ComfySofa
« Reply #466 on: September 26, 2023, 08:28:50 PM »
Brilliant - many thanks....ill go through.
Offline ComfySofa
« Reply #467 on: September 26, 2023, 08:48:41 PM »
Not sure i can do all the test on the doc - ive got a digital meter so not sure how to set mine the same way but the youtube video i found both checks are fine.....as ive got a lithium battery and, a brand new reg/rec to match the lithium battery (wasnt cheap) - ive just started it again and as i rev it i am seeing the voltage increase not jumping masses but it is going up.....if i leave it at tickover i see about 12.74 ish - rev it to about 3k and it goes up to 12.8......if its dry tomorrow ill take it to work again and then see what the voltage is...
