Author Topic: Spade connectors  (Read 618 times)
Offline smoothoperator
Spade connectors
« on: April 27, 2022, 06:50:40 PM »
I need to replace a couple of wires in the spur from the generator to the block connector that sits on the left hand side of the frame. These terminate as female bullets at the generator end and as male connectors in the block. Does anyone know the correct type. Kojaycat list 0.5 to 1 mm squared and 1 to 2.5 mm squared. Also is Kojaycat the best source, I seem to recall they have a £15 minimum order, I've bought some other bits from them before. Maybe I need both, the green wire is thicker than the white wire, these are the field coil connectors.
« Last Edit: April 27, 2022, 07:38:29 PM by smoothoperator »
Steve
2017 Triumph Bonneville T100
Offline Deano400
Re: Spade connectors
« Reply #1 on: April 27, 2022, 08:11:31 PM »
Are these any use?
https://www.autoelectricsupplies.co.uk/product_list/2
I think delivery is £3.50 and I don't think they have a minimum order value.
« Reply #2 on: April 27, 2022, 08:55:23 PM »
Thanks Deano that's a useful link.
Steve
Offline Deano400
« Reply #3 on: April 27, 2022, 09:16:06 PM »
