Author Topic: Oil seal for cb200 gearbox shaft (sprocket end )  (Read 858 times)
Offline shifter
« on: April 28, 2022, 11:39:03 AM »
  I have been trying  to purchase with no avail  a gearbox shaft ( sprocket  end) "oil seal" , NGK AE1061F.. I'm wondering if some one can help me where to purchase  for a CB200 .. I didn't want to remove the one that's in the bike incase non availability...
" RIDDEN NOT HIDDEN"
 Moto morini 250 2c
Cb200
S90
Offline sye
Re: Oil seal for cb200 gearbox shaft (sprocket end )
« Reply #1 on: April 28, 2022, 12:02:19 PM »
A quick search suggests that this is a 25 X 38 X 8 rotary shaft oil seal. Readily available almost anywhere, such as here:
https://simplybearings.co.uk/shop/p26287/25x38x8mm-Nitrile-Rubber-Rotary-Shaft-Oil-Seal-with-Garter-Spring-R23-/-TC/product_info.html
HTH
Offline mickwinf
« Reply #2 on: April 28, 2022, 12:06:51 PM »
I know nothing about cb200s so i looked on cmsl and it gives a 20 x 52x9 if its the one behind the final drive sprocket? as Sye says, available from honda specialists or bearing suppliers.
Offline Deano400
Offline shifter
« Reply #4 on: April 28, 2022, 01:32:52 PM »
Hi guys many thanks for your input ,much appreciated.
 Moto morini 250 2c
Cb200
S90
