Author Topic: Rotor stuck. Is there a trick?  (Read 1807 times)
Offline heli_madken
Re: Rotor stuck. Is there a trick?
« Reply #15 on: May 04, 2022, 04:24:15 PM »
I seem to recall using an M16 x 50mm fine thread bolt - https://www.spaldingfasteners.co.uk/m16-metric-fine-8-8-grade-high-tensile-zinc-hex-head-fully-threaded-set-screws/ and an impact wrench, just seemed to fall off my 77 550K3 as soon as I pressed the trigger. This would work I imagine even with the crank out of the engine.
Offline alexdecker
« Reply #16 on: May 06, 2022, 07:24:56 AM »
It's off. Definitely didn't fall off at all. It took a big hammer and what some would call violence and everything on my work desk rattling off and falling to the floor.
But… it's off. I think that was the last thing that could be stuck on this damn thing (knock on wood).
« Reply #17 on: May 06, 2022, 07:48:02 AM »
Congratulations Alex. Don’t be downhearted, regroup and crack on. You’ll feel a lot better once to start to rebuild.
