Author Topic: Crank not rotating  (Read 6062 times)
Offline alexdecker
Crank not rotating
« on: May 06, 2022, 04:51:15 PM »
Just connected to the halves of the bottom end. My crank seems to be stuck though. Checked the gears before installing and they were fine.
Is it supposed to be able to rotate free at this point?
Online Bryanj
Re: Crank not rotating
« Reply #1 on: May 06, 2022, 05:09:10 PM »
Something is put togerher wrong, should turn easy
Offline alexdecker
« Reply #2 on: May 06, 2022, 05:24:58 PM »
It happens when I torque the 10 main bolts down. 17 foot pound is my spec. Why is this??
Offline alexdecker
« Reply #3 on: May 06, 2022, 05:35:06 PM »
Just went down to 14 foot pound. Still seizes when I tighten.
« Reply #4 on: May 06, 2022, 05:46:18 PM »
Wrong shell in wrong location?
Check nothing under the shell making it stand prouder.
« Reply #5 on: May 06, 2022, 05:48:12 PM »
My thoughts.
1.Is it in neutral.
2.Is the cam chain free.
3.Did you Plastigauge the mains.
4.Are the conrods free.
Offline alexdecker
« Reply #6 on: May 06, 2022, 05:57:00 PM »
Everything is free. I didn’t plastic gauge, as I marked the location of each bearing and put them back in the same place.
Offline murdock
« Reply #7 on: May 06, 2022, 06:19:27 PM »
How big was the hammer you used to remove the rotor? ......
I'm scared of you. ;D
Online Bryanj
« Reply #8 on: May 06, 2022, 06:21:05 PM »
You did put the shells into the cases with cases and back of shells dry didnt you,mixing up shells would not normally lock it up, i have built with all tightest shells before now with no problem.
Primary shaft needs to be fitted and cam chain free but should turn by hand.
You havent tried to miss match cases?
« Reply #9 on: May 06, 2022, 07:20:27 PM »
Crank seal located correctly?
1978 Honda CB550K3.
« Reply #10 on: May 06, 2022, 07:23:37 PM »
A black in a yellow location might lock it Bryan but I was more thinking of something behind the shell making it bind onto the crank.
« Reply #11 on: May 06, 2022, 07:33:34 PM »
I assume the upper half case was upside down when you started assembly. Did the Crank rock freely when sat in the Crank mains with assembly lube applied? I am assuming it not significantly different to a 400/4. I
Can the Crank be fitted in the wrong way round.
Offline alexdecker
« Reply #12 on: May 06, 2022, 07:40:03 PM »
Oh god, I hope I didn’t do what you are referring to!
Offline alexdecker
« Reply #13 on: May 06, 2022, 09:12:05 PM »
I did exactly that. Pretty sure I mounted it the right way. And yes, it moved freely.
Offline alexdecker
« Reply #14 on: May 06, 2022, 09:16:04 PM »
I only lubricated the crank contact side of the shells. I fear that the crank might have gotten bent when I put the hammer to the rotor puller to get the rotor off.
Still - I didn’t have the crank in a vice when I did that, so it could move freely, and the rotor puller and rotor contact point seems too small to be able to bent the crank like that. But it’s the only possible thing I can think of happened. Everything else is in its right place. When I torque it down with my drill, it still rotated freely. But with the torque wrench it seizes up 😕
