Author Topic: Tool buying Advice requred  (Read 2859 times)
Offline Eldrick
« on: May 14, 2022, 01:55:24 PM »
 I want to do more work on my 400f myself and I think I want a torque wrench and a carb synchronizing kit.
 I keep looking online and get overwhelmed with choice. The other issue is I don't really know which is best overall for this specific bike rather than ‘the best make’. No good having a best make torque if I can't perform most/all jobs on my bike and end up buying another one.
I also thought I wanted a single gauge, four into one, sync kit, I could be fooling myself though. I liked the idea that all four carbs were being tested on one gauge.
 So, if you can recommend a good torque wrench and carb synchronizing kit I can get started on being a shed mechanic and maybe even get a second (His and Hers) 400f.
1975 Honda CB400f - Red
Re: Tool buying Advice requred
« Reply #1 on: May 14, 2022, 03:02:21 PM »
Decent name 3/8 drive torque wrench and sealey 4 gauge set which costs about £120 on ebay, single gauge sets will drive you crazy
« Reply #2 on: May 14, 2022, 06:07:58 PM »
My trusty Britool 1/2" wrench was too big so I bought a 3/8" Draper. Good tool but the Imperial & Metric Scales are in Inch-Lbs or Newton Metres range is 10-80Nm. I had to do a conversion for all the settings in my manuals.
Offline Eldrick
« Reply #3 on: May 14, 2022, 06:47:55 PM »
Ha, see, I didn't even think about all that maths! Glad I asked before buying.
« Reply #4 on: May 14, 2022, 07:32:03 PM »
Get a Britool 3/8 torque wrench if you can. That will cover 99.9% of the torques on your bike. Don't worry too much about vac sync gauges, you can set the slides very, very, very close by manual bench sync.
Offline Eldrick
« Reply #5 on: May 14, 2022, 09:07:44 PM »
I may have just done that bit with 3.2mm feeler guage. I also think I can afford that wrench if it is the Britool AVT300A
« Last Edit: May 14, 2022, 09:10:59 PM by Eldrick »
« Reply #6 on: May 14, 2022, 09:15:18 PM »
Not sure that model has a high enough range at 33Nm?
« Last Edit: May 14, 2022, 09:16:53 PM by McCabe-Thiele (Ted) »
« Reply #7 on: May 14, 2022, 09:21:59 PM »
3.2 is a bit big, better using a 1/16 drill bit shank preferably new so no damage
Offline Rozabikes Tim
« Reply #8 on: May 15, 2022, 08:14:22 AM »
ok so what torque range do we need?
« Reply #9 on: May 15, 2022, 08:29:14 AM »
If you want to torque every thing 8 ftlbs to 50 ftlbs, leave out the alternator, primary gear and clutch nut and 8 ftlbs to 20 ftlbs will do.
Those 3 are normaly done to BT.
Gauges are Sealey VS209 gone up to £150 cheapest on ebay, nearest thing to genuine Honda ive seen anywhere
« Last Edit: May 15, 2022, 08:33:01 AM by Bryanj »
« Reply #10 on: May 15, 2022, 08:42:45 AM »
What's BT Bryan?
« Reply #11 on: May 15, 2022, 08:55:04 AM »
Bleedin’ Tight (?)
2022 Tiger Sport 660
Offline Eldrick
« Reply #12 on: May 15, 2022, 09:04:44 AM »
OK so about 1.5mm, I may have a dril bit, if not the guage will do it
Offline Eldrick
« Reply #13 on: May 15, 2022, 09:08:08 AM »
I don't anticipate ever replacing pistons myself but I would be ok replacing gaskets in the head. I also would not be touching gear boxes, so with that in mind, what range may I need?
« Reply #14 on: May 15, 2022, 09:20:51 AM »
Personally the torque wrench I use most is my Seeley 1/4“ as a) it came with a calibration certificate and b) the range is low enough for the 8ft/Lb for 6mm bolts (and there are plenty of those on the 400/4 engine). My 3/8 torque wrench starts at 10ft/Lb and is not accurate at 8ft/Lb, ask me how I discovered this! If you are going to strip a thread it will be a 6mm!
If you can afford both get a 1/4“ and a 3/8". If you go to one of the larger shows Seeley normally have their stand with some deals on (or try eBay).
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
